Tried to make an appointment before but the waiting time was too long. Are you going for checkup or any specific procedure?
Do you know how much are the scaling and polishing charges?
For Singaporeans consultation, scaling, and polishing costs $16 plus each, at both national healthcare group, and singhealth polyclinics.Do you know how much are the scaling and polishing charges?
Polishing itself is rather enjoyable in my opinion haha. The dentist would use a tool to gently buff your teeth.Is polishing advisable for those with sensitive teeth? Is it painful in the first place?
If you are afraid of sensitivity after polishing and scaling, then perhaps you can ask the dentist to include a fluoride treatment at the end.
You will be ask to bite down on something like a mould, that has blueberry flavoured fluoride gel for roughly a minute. After which you will be asked to rinsed your mouth and the session will be over.
However this would increase the cost of your visit. Not too sure how much fluoride treatment will cost though.
Never knew about the time limit regulation before.Thanks for sharing.
Might consider to include this procedure if time permit. I heard each patient is allocated certain time limit per visit so may have to wait till the next appointment to continue.
When you have arrived and are registering yourself at the counter, tell the staff the procedures you would like to get done for the visit. He/she will let the dentist know.
Upon entering the room, the dentist should confirm with you again, if the dentist do not, you can tell them what you would like done.
Do polyclinics handle wisdom teeth extractions?
I can confirm the time allocated per patient is 20mins for Jurong Dental Polyclinic. The time is usually enough for single procedure like fillings/extraction. So if you need multiple procedures done then no choice but to schedule multiple appointments in total.
20mins includes consent taking etc.
The unofficial guideline is usually 1 treatment per visit. So each visit can only do either cleaning or 1 filling or 1 extraction. Unless the dentist is very fast and kind, or that day happen to have many patients who do not turn up for appointment, you will have to go back many times to fill if multiple procedures are required.
I doubt they factor in the time for local anesthetics to take effect because immediately after injection, the dentist simply carry on with the procedure without waiting. I felt the full effect only after leaving the clinic which lasted up to an hour!
The chances of patient not turning up is very slim given that they stand to lose the $8 deposit if never turn up for appointment. I have witness patient who walk-in with no appointment and was told to come the next day at very early hour to try their luck.
