DDR4 RAM Speed
YCT_49
I bought parts for a new PC yesterday. The Corsair Vengence LPX 2 x 8GB RAM was marked as 3000 MHz on the box. But in the BIOS, they are indicated as 2166 MHz. Anyone here can help me to clarify why the actual speed is lower than that marked on the box? Thanks in advance.
Wataru
Depending on your motherboard, you have to either manually set the RAM speed, or enable the RAM's XMP profile which indicates 3000Mhz
Phen8210
need to set xmp profile, for ryzen may not have 3000. then u set lower.
Ferolare
which platform though..
amd: enable xmp profile in bios
intel: xmp should be an option if you have a z370 mobo. otherwise... you might need to manually set memory speed to 2666 along with the timings
Crooni
that's the standard default speed for ddr4.
how would the motherboard know what ram you're using and what its' specs are
how would the ram manufacturer know what motherboard you're using and its config/features
that's how it boots, by using the default industry settings
when you enable xmp/amp, you're telling the bios to read an info chip on the ram which contains the settings for that ram. or you can brute force by setting its speed/timings yourself, which is how overclocking works.
YCT_49
Noted with thanks. Will try. My motherboard is Asrock B360 Gaming K4.
YCT_49
Thanks for your clarification. Will try it out later.
YCT_49
My motherboard is Asrock B360 Gaming K4. Will get into its BIOS and see what I can do. Thanks.
orange_20
you using a intel non-K processor with a H or B series mobo? then the max speed is only 2666mhz.
my 3000mhz ram also only run at 2666mhz. using i5 8400 with H370 mobo.
Under OC in BIOS, I can set max speed of 2666 only.
finclk82
Oh... means have to get Z370 intel chipset motherboards to be able to use more than 2666mhz ram speeds?
I noticed more and more games these days do benefit also from higher CPU and Ram speeds already. In the past, these factors didn't matter as much as the GPU solely
Koenig168
Difference is just a few percentage points for RAM speed. Just avoid anything slower than 2666 MHz.
