Jirachi
- Jan 17, 2010
Dbs version is now compatible with beta. Not the posb version yet
Sent from Wireless@SG using GAGT
Can confirm this too.
That soonThis does smells like they are expecting the GM to drop on Monday.
Posb and dbs all working after app update.
Thanks for headsup
You don't understand usually these apps target the latest SDK levels for security reasons. And any level too low their required levels or too high will usually result in an error or lockout to prevent tinkering. OR they are using a specific API call that has been changed from expected behavior resulting in a crash.
Apple at the moment DOES NOT take in any application submission with iOS 12 targetted until GM build is released where APIs are finalized and fixed
Anyone tried the carplay ? Is it stable with Waze or google?
Yours is iPhone X ?
Any 1 have any idea why screen time not showing the past 7 days record?
Try reset the setting “share across devices” off and back on if you enable on mutliple idevices . Mine was weird before last reset
Did you update your OS? Usually it resets after an OS update from what I've seen with the betas so far.Any 1 have any idea why screen time not showing the past 7 days record?
Doesn't matter. It's the OS level that is affecting the DBS/POSB and other banking apps.Yours is iPhone X ?
