Official OnePlus 6
androidmazon
I am using this combi, yes, it does affect the top two corner of the tempered glass. I switch back using the transparent case provided in the box.
Oneplus official tempered glass should go well with Spigen rugged armor case, I've no problem with it. I think your tempered glass alignment could be a bit off to the top, that explains the top two corners being affected by the case.
I've tried a few so-called full coverage full adhesive tempered glass, so far only the below two fitted perfectly with no halo effect. However Oneplus official tempered glass is slightly smaller than that of the InvisShield full adhesive tempered glass, it is hence more case friendly than the latter.
Oneplus Official 3D Tempered Glass
InvisShield Full Adhesive Tempered Glass
I've tested the above two tempered glass with some cases that I had, here is my test result:
halocast
Question. Does the original OnePlus 6 cable typc c allows data transfer? Can connect to PC?
Fixed. Haha
kkcheng77
Does Oneplus 6 has Volte or Clearvoice (singtel) enable?
For those who cannot have Volte enabled
Can you try this?
key *#*#86583#*#* in dialler. If this works on both A6000 and A6003, Oneplus 6 will be my next phone upgrade.
Let me know if it works. (Works on my Mi5s btw)
androidmazon
Can you try this?
*#*#86583#*#* doesn't work on Oneplus 6, dial *#*#4636#*#* instead.
VoLTE provisioned switch is not turn on, you can turn it on but it won't stick.
A couple of pages back got discussion on how to enable VoLTE (with root), you can check on it.
contacted
I can't get it to even turn on, mines an export set.
mlwang
Thought don't need to root?
w/o root--> open the dialer: *#800# --> oneplus Logkit --> Function Switch --> enable VoLTE + VoWifi switch
androidmazon
tatsit
High Honorary Member
Refer to the guide in my post. After enabling the VoLTE switch, you still need to edit the EFS.
Fellowes
Yes, VoLTE and WiFi calling switches appears after using this method, but VoLTE doesn't seems to work, it still drop to 3G or H(or H+) when making phone call..
Apparently it's supported all along just that our 3 telcos never work with oneplus to officially make it work on OnePlus phone since they don't sell the phone through Telco here. It's really too bad. It will never be activated until they start selling it via Telco.
Activated using *#800# option appear after reboot for volte and wifi calling but it don't seem to work as the volte icon don't appear on the notification bar.
Lazy to root and change EFS stuff, forget it. Just hope it will be officially updated to support volte and vowifi in near future.
androidmazon
Need root for editing the EFS partition? Will it affect future OTA updates?
Me old age already, no energy to play with all the root/twrp stuff...
