[Official cycling thread]
konoha
anyone can recommend me a MTB (hardtail) less dan $400?
Or which brand is more worth getting?
Giant / Polygon / trek / etc?
strictly no aleoca pls.. haha
batuchka
< $400 locally and brand new you most likely looking at Polygon loh unless consider 2nd hand bikes?
Blahhh
Hi all, Iam new to cycling... Pardon me for asking a noob question... I realise my speed is v slow... Other ppl (on road bikes) paddle once already overtaken me by a few ten's of metres... My average speed is only around 9.5kph... I am a buibui riding a 20" Aleoca Foldable bike... So is it the bike issue or just my poor fitness level? And to ride on average 2 hours per trip, my bum feels sore... Especially the tailbone..... So changing to answer bike or bigger saddle helps?
Thanks!
I am guessing your saddle height is too low (typical mistake newbs make) and you are riding in a too high of a gear. I assumed your aleoca foldie has 6-7 gears, try riding on a low gear (1 or 2) and "spin" the pedals (meaning pedal fast, aka high cadence) instead of grinding on a high gear.
smurfzzz
Im trying to find a tricycle with big cart in front to fetch my big dog without luck. Found some online from europe manufacturer but the fees are 3000 euro and above minimum. If got any good lobang, pls share with me, tkz u.
aireth
Anyone know a good bike repair shop in Sengkang?
Seems like most offers only full servicing and not adhoc ones.
jsl2012
how cheap is you budget??
SSPU bike SGD 160 u can get at carousell
Hito X4 / 6 SGD 350 - 399 can get at carousell
Java zelo SGD 300 - 350 can get at carousell
This above only shimano 7 speed with normal rim normal tyre and normal brake
bbqbeans
Any diff between the SSPU / Hito X4 and Java Zelo ? Or actually quite similar just different brands?
Icingdeath
Hi does anyone know which hawkers centers are foldable bike friendly and allow you to put your bike under or next to the table you're sitting at?
AlwaysHardAlwaysReady
just bought rifle R8.. any review on it ?
LTWOO A5 9 speed.. 10.5kg.. bifold..
damage 410 dollar..
bought accessories
front and rear light
helmet
cable management
bell
bike lock
manual pump (scare those automatic pump cannot last)
phone mount..
anything I should take note ? or miss out..
first bike noob here
batuchka
damage 410 dollar..
bought accessories
helmet
cable management
bell
bike lock
phone mount..
usually i would add a small on bike bag wif spare tubes and multi head bike tool loh :giggle:
batuchka
there will be a small bag free gift by seller..
what bike tools are usually needed ? planning to ownself upgrade in the future after experiencing with this bike
multi head tool like the below
i like mine wif chain breaker and torx head cos use bikes wif disc brakes and like to ownself change and install chain after worn out ^^
