[OFFICIAL] Taiwan Guide and Taiwan related matters - Part 8
calkel20
running tights only ok if u got sexy legs :D me prefer track pants
i no longer wear jeans for traveling becoz heavy bulky & doesn't dry fast
Wear it okay la.
If need to dry it, find dryer or hang in room with aircon.
Then last option is to go borrow iron.
calkel20
if the flight is 12am, i will reach check-in at around 8pm. then walk around in the public area and transit area. 2 hrs before boarding will go lounge to eat and relax. haha.. go holiday or travel for work must relax relax lah...
Travel for work very atas.
My lounge and your lounge huge gap.
MiImbEn
yea.. me also similar i usually reach airport abt 3-4 hours before the flight
go in jalan jalan beo stuff
Andrew833
If not that cold ok, but if cold jean work best lol. I went china, temperature sudden drop from 20+ to 15C, lucky I got bring jean.
Duncallmebro
Might sound a bit crazy, my flight is 7am, can bring my family in just after midnight?
Realised that we have not really explored the transit area, though things may be limited at such early hours
Another question, any lobangs to get a Taiwan sim that allows us to extend expiry? Cause likely to make multiple trips in a year
Andrew833
After midnight, public area very quiet, transit area not so bad. But so early, go there sleep ah.
Andrew833
Extension of SIM Card duration or stored value is not permitted.
Chunghwa Telecoms 中华电信 SIM Card will automatically expire after the number of days purchased. (SIM card you buy from airport)
Only way, I think is buy prepaid sim card. Bro Calkel should be able to help :D
calkel20
If you got boarding pass, you can go into the transit area.
Taiwan sim, if you get at airport, you can try enquiring from them.
Duncallmebro
No check in cannot.
Early check in mostly for full-fledged flights.
ah, mine is Jetstar
Does this apply? flight 3k721
"If you’re departing from Singapore’s Changi airport on a Jetstar Asia (3K), Jetstar Airways (JQ) and Jetstar Pacific (BL) flight you can use our early check-in facility, up to 12 hours before departure."
Duncallmebro
Cause if wake up in the middle of the night to go airport, like neither here nor there...haha
Thought maybe can chill at the airport or even check out the free cinemas
calkel20
ah, mine is Jetstar
Most welcome to try and let us know.
Jetstar, if states so. Should not be a problem.
dede1217
ah, mine is Jetstar
Normally for jetstar, you can use their machine to check in yourself ...
you can select the flight number
from there, they would print out your boarding pass ...
dede1217
Tomorrow flight, 16 sep
jetstar to taipei:
1.10am flight, revised to 9.55am
7am flight, revised to 2.50pm
calkel20
jetstar to taipei:
Likely they worked the time shift out for the typhoon delay.
Great job i must say.
Wonder as such, i think no claim right?
