Both are single boiler, not recommended if you drink mainly with milk.Need recommendation to upgrade my espresso machine.
I’m using DeLonghi ec680 and Breville smart grinder pro now.
Any espresso machine to recommend? My budget maybe around $1200. Grinder still can use my current one. Think it’s still good enough. My main concern is startup time as I make my coffee every morning before I go to work so I can’t afford 15mins before start pulling.
How is the Gaggia classic at $729?
What about Lelit Victoria but it’s at $1399. https://cowpressocoffee.sg/collections/equipment
Hi
When you turn on hot water for 680. Does it shudder and shake
My Delonghi extract about 15s from single 7g. Normal? Or must tamp harder. Already at finest grind
No leh. Does it happens to yours?
Bottomless helps to correct prep work, ie, distribution, tamping, etc
Seeing how the pour starts and end can give clues on equipment and prep work.
Taste wise i am pretty sure there is not much difference compared to single or double portafilter.
can be frustrating as well. U maybe making alot of coffee.
ppl who can taste the difference sure it affects but if U cannot discern the taste in a blind taste test its not worth while.
Yea I drink milk drinks now. What’s the difference between thermalblock and single boiler? I find my ec680 now is quite ok. Don’t have to wait too long.
Thanks. I'll focus on beans for now and maybe save up for a better grinder than BB005. Any suggestions? Mazzer Super Jolly?
Single boiler takes a longer time to heat up to steam milk.
How much longer can be 5-10mins. Does it makes poor steam amd makes it unsuitable for milk base drinks no.
If I can afford the time great.
The BB005 is a very capable home grinder, comparing to a super jolly in a not commercial setting, i dun see the super jolly being superior to it. The mazzer jolly adjustment is very finicky, and not very pleasant to use at all, especially when single dosing.. The only superiority i see is the speed of grinding.
The BB005 however suffers from major retention, but comparing to the super jolly with out mods they are nearly on par.
The most important setting is the fineness of your coffee calibrated with your grinder and it can't be automatic.![]()
For Strega double shots, do you follow the 18g guideline or do you tend to overdose? I tried overdosing but it seems to trickle down to the point of almost choking. Adjusted the grinder size also about the same.
Means you need to turn more rounds to make it coarser lor. Or use lesser dose.
For dark roast, I use 15g. Lighter roast, 18 to 20g![]()
Adjust what?Noted. Will finetune further.
Still getting used to the steam wand. So far not successful as my milk tends to get hot very fast before it becomes creamy enough for latte. Maybe I should manually adjust it?
Well I guess a heat exchanger is the best option for my need as I drink primarily milk based. However I don’t know which ones are affordable and suitable enough for my needs. I like lelit because it has lcc so it can prompt me cos I’m a noob. I was also looking at the lelit Elizabeth but it’s pretty expensive but it stops the shot automatically.
BB05 is should be good enough for home. I found it pretty decent. Significant upgrade would be a grinder that is designed for single dosing. HG one, Sette, Kafatek, or even a ceado E37s.
Or more controversially, large flat burr grinders, if you subscribe to the "even grind consistency is better" camp.
e.g. mythos one, EK43, Peak, kafatek flat, LWW EG-43
