Ryzen System with Windows 7?
singupingu
front they dont recommend ...
Watch some YouTube video on this. Front or back mounting, same same in the end. All within physics explanation.
Mount in front as intake, your ambience air inside case will be slightly warmer. GPU temp will be slightly higher but CPU temp is lower as the radiator is cooled by fresh air.
Mount at top as exhaust, your ambience air inside the case is cooler. GPU temp will be lower but CPU temp is higher as radiator is cooled by the warmer air dump by the GPU.
Best scenario is top/rear mount as exhaust, GPU use blower type. So, both GPU and CPU is cooled by the fresh air and not affected by one another.
Here's the video I talk about:
If front mounted is bad, how the hell NZXT award winning chassis, the S340 series and their new H500 series sell so well? If it fails like the Cooler Master H500P (OG, first gen), it shouldn't sell so well. Some technical failures are unacceptable, but some are within means and reasonable of aesthetic/functionality/cost standpoints.
Sent from OnePlus ONEPLUS A3003 using GAGT
croc1977
i meant due to gravity ...
they explain if on top the radiator will pump 'below ' and without lag while if mount side the cable may or may not straight causing extra requirement to put 'up' to the cpu
even you place air con if i remember correctly similar logic when during the trunking...that why gain city told me...the way you place the pipes will determine how your air con last also...
croc1977
anyway after a heart pain ...and tedious process i manage to install..
so correct way U need a PS2 KB
even adding the driver into the iso doesn't work. using the asrock or msi windows patch software
my casing and board no USB 3.0....really suffer...
i need to take out one of the non os SSD ...place the files in the SSD then add the driver after window install. you face challenge cos the usb 3.0 drivers will not load during creating your name and pc name page....u need ps2 keyboard. spent $5 to get one...
Haven OC yet but why ram is 2400 only even tot i bot 3k models?
singupingu
For RAM, anything above 2133MHz (some are 2400MHz, highest without overclocking I've seen is some of the Coffee Lake builds which detect 2666MHz automagically) is overclocked with XMP profiles. You need to go to the BIOS to use XMP and overclock it manually with the timing provided by your RAM kit.
croc1977
so my ram indicate as 3k so i need manually change to 3k?
singupingu
In most cases, yes. Your ram indicate 3000mhz, means it is guaranteed to reach 3000mhz based on manufacturer testing and the timing given by them.
At any case, Ryzen run 2933mhz instead of 3000mhz on the dot due to whatever reason. I forgot what, something about the way Ryzen calculate the timing and its multiplier, which I can't recall exactly what.
croc1977
Try and see how low of the core voltage you can go before it give you problem. If you can run around 1.35V or less, then it's a nice chip.
i put 1.375v....haven load yet...
croc1977
right now im running 4.15mhz...plus 1.365v core
anything more or less may not stable...tried 1.35v system hang
Phen8210
put 2933, ryzen cannot 3k... dono y also.
my cpu voltage can shoot to 1.5v :s13: :s13:
singupingu
Still good. Your chip is pretty decent coz 1.365V isn't high at all, considering I'm running 1.38+V for 3.9GHz on first gen Ryzen hahaha
croc1977
haven really load it...keep using play pes 2018 nia...
swbf2 and other maybe weekend.
