LG V20
mie28
chooyoshi
Just receieved android Oreo OTA on the V20. It is doubtful that it will get pie afterward
lgmw33
Update really took ages. Finally decided to get it done overnight. Phone performance seems better after the update.
benben
anyone's v20 run quite sluggish? tried factory reset but still same results, even after oreo update
for no reason it became like that a few months ago, although not main phone but still use it sometimes for music and videos
Marcus Teo
Bought a 4100mAH battery from qoo10 recently, battery is standard size but can last much longer than original :D
Kcusts
Pls share link...
Sent from LGE LG-H990 using GAGT
First post just to recommend a battery. This guy might just be the seller. :o
If it's a good battery I don't mind, but power don't come out from thin air. Unless you are telling me it's using some sort of revolutionary technology, the higher the capacity, the bigger the battery must be. There are a lot of high capacity "gold" batteries on eBay. They can print anything they want on the label but the performance is terrible.
tiredman
Guys may i know how to restore accidentally delete photos n videos from my phone ? Thanks
