It affect the google assistant but in a good way.
Previously the link between ihc app and google was very bad. It was a hit and miss and very messy. Its like you can control using ihc but you cant control using google assistant/ google home. You ask google to turn on bedroom light, the whole hse lighting might turn on or some work and some dont or some other problem will crop up. You need to revert to an older version of ihc to get things working.
With the latest version, it seems that everything is running good. Best things of all, google come up with indicator to show if the light is on or off without pulling neutral wire to the system.
I'm still testing my setup. Currently im very happy with the latest update.
May I ask if this also affects Google assistant as well? I'm thinking of getting a GH. But shouldn't a change in GH interface affects the iHC only? Why do you need to reprogramme the switches again?
