Oneplus 5T
Eddied
My 5T has been experiving very bad battery life after installing the latest update. Anyone else same situation?
check if android system is using too much battery, you should clear cache in recovery mode after updates
Alphaen
Just checking, I'm on Singtel mysim plan. I experience data not connecting issue very often. After a while, it will become no service and I have to reset my phone. there are times I cannot send SMS at all.
Does anyone face with similar situation?
Sent from OnePlus ONEPLUS A5010 using GAGT
I have this problem too. Sometimes suddenly phone will not have internet, just 4G without 4G+ signal. Many times I'm not able to receive sms when I'm expecting it e.g. sms token for singpass. Need to restart phone then can receive.
Eddied
for sms problem, can try switching on flight mode for a few seconds then switching it off, oreo got this problem for some ppl
hiakhiak
How is everyone's 5T holding up? I'm actually thinking of getting one now. I don't like notches so I'm not considering 6 or 6T. Hoping that 5T could last me until this notch phase passes...
lousydrinker
I think notch on 6T still ok, u can even use software to hide the notch
Posted from PCWX using ONEPLUS 5T
hiakhiak
Thanks, but I prefer no notches. About hiding the notch, wouldn't there be like a reverse burn-in since that part of the OLED is never used?
The battery drain in concerning... It wouldn't have been a year assuming y'all bought from launch.
lousydrinker
Mine less than a year, local set. still got warranty
rollanddie
Anyone else notices if using dash charge, the battery life is not as good as normal charging?
Skyy
depends on whether u dash charge till 100% or not. the stress on the batt is greatest when it's nearest to being full...
