Apple Watch Series 4
tohchr
How to show the distance at the bottom left.. mine is only showing steps count and the meter. Using stepsapp pro...
Think u need to walk another 2000 over steps then it will show. :s13:
tohchr
Any good suggestion or opinion whether we should get a 44mm stainless steel gold or Hermes edition? Tia.
Unless u like those Hermes strap, else not worth to spend that kind of money. U can get 2x stainless steel watches when u buy one Hermes watch.
raisins
I'm looking for the 44mm nike + edition space grey aluminium. Anyone knows which shop has stock?
punggolkid
Is anyone here having the “light bleed” issue on the S4? I’m on the 44mm aluminium version and while it’s quite minor and not visible in broad daylight, I’m considering getting a swap.
tohchr
Bleed at which part? Care to take a photo?
sdarren7
I have. Exchanged my 4th watch finally no issue. Yes. Only visble on grey background. It looks perfect with bright light. But once dark like in the car at night super obvious.
To check just use map, ask for direction,turn by turn direction background left side always so much brighter. Now my watch dont have such issue
sdarren7
Left side. Accidentally notice it when use map. Left side brighter
Different watch. Same issue
See all 4 date complications. Left side lighter. If u screenshot. U view at iphone. All complications same light tone. Means the watch got issue
Different watch same issue. Left side brighter
Now finally ok after last swap ytd morning. Lucky gold ss got stock back. Cos in the middle i change to space black due to no stock
tohchr
I see. Now I get it. Later I get in my car then I check.
punggolkid
if i were you, just get it returned.
pls share a photo of your issue, let us check ours too
Was browsing the menu in the dark in my room when I first noticed it:
Next, I downloaded a grey photo to the watch to compare. There is significant unevenness in the lighting of the screen.
A couple more people seem to have this issue as reported on Reddit:
https://www.reddit.com/r/AppleWatch/comments/9i3lod/experiencing_weird_light_bleed_on_series_4/
klho001
Love the 14 day return policy. I couldn’t decide on the right model so I bought, tried and returned when I felt it didn’t suit me. Did this a few times am now on the SBSS and I think this one’s it :s13:
mackie8
U tried which model?
Snoweagle
That's bad and totally unacceptable. I've checked mine in complete darkness and it's as clean as a whistle.
