Huawei Mate 20
tohchr
Already did that. Same problem. It's like the phone is always giving the Singtel SIM higher priority.
The weird thing is that when I disable the Singtel SIM, the Digi SIM still cannot work. I have to remove the Singtel SIM from the phone before the Digi SIM starts to function properly again.
Did u swap your data from sim 1 to sim 2 or sim 2 to sim 1?
techizen2
Did u turn off the call forwarding sim option? And set the default sim and default sim calling when you travel back to msia
Call forwarding always switched off. Tried default SIM to Digi does not work also.
Tried selecting manually the Digi SIM also cannot. Only way for the Digi SIM to work is to have the Singtel SIM being removed out of the phone.
tohchr
Yes. Already did that. Same problem
Somehow I think there's a bug when u had 2 sim cards, change the default data card. I encountered in my P20 Pro as well. U can try to simulate the problem again..
techizen2
I changed Default to Digi. Tried calling or SMS and pressed the only button available i.e. Digi. But it still ended up using the Singtel SIM.
If others using Dual SIM don't have this same problem, I guess mine's a lemon then. Will have to go to their Service Centre :(
weiiix
Thanks for all the recommendation between Mate 20 and P20 pro.
Abit hard to decide. Design wise i prefer P20 pro more follow by mate 20 and mate 20 pro.. Im also looking more at the camera specs as my mi max camera really sucks. My main usage is surf net, listening to music (using bluetooth headset) and watching videos.
tohchr
Under dual sim setting, default calling sim, "not set". U will 2 buttons available instead of one button.
tohchr
I'm using the app 'musicolet". Quite a nice music app to pair with P or mate series.
tenshinoir
Maybe u call the svc centre and see what they say. My p20 pro didn't had such issues. M20 pro idk yet cos haven't travel
vaio2000
full adhesive loca glue tempered glass. works fine with in screen fp scanner. able to fit the default case.
30 bucks @ red white.
Bro, may I know where is red white? Am looking for the tamper glass.
Do advise?
techizen2
Yes. If default is not set, you will see 2 buttons. Singtel and Digi. Pressing Digi will still end up with the Singtel being used instead of Digi.
Same problem even when swapping their tray location or disabling the Singtel SIM.
Only way for the Digi SIM to work normally is to take out the Singtel SIM completely.
It's like this M20Pro (from Singtel Comcentre) must always use the Singtel SIM even when the Digi SIM card is selected.
Skyy
You mean when you totally disable the Singtel SIM in the settings menu , when u try calling out via the Digi SIM, it'll turn on the Singtel SIM, wait for the network to connect then make the call?
phrozact
Hmm somehow I don't see hwz ads using chrome. Is it due to the huawei VPN? If it is it's so cool to not have to install adblocker sia.
It does seem to have some sort of adblock in place, and while it's nice I'm actually trying to find how to disable it. It's preventing me from loading those 30 sec ads that I can watch for in-app benefits...
