Huawei Mate 20
athenodorus
You still encounter inconsistent fp scanning performance?
Sent from Samsung SM-N950F using GAGT
It’s not 100% accuracy. I would say 70%?
update: it seems to be working fine today. lol. sot sot one.
chenaz
U need to go to Whatsapp setting and change .
Under settings/notification/lights
After factory reset, both my SIM cards functioning now. Singtel Postpaid as SIM1 and Digi Prepaid as SIM2. I stayed away from Phone Clone this time.
In total darkness, my phone have totally no bleeding light.
My only problem now is all my Notification Badge is just a green dot. Can't find a way to make it a numbered red dot.
jlekssp
It happen again while using the phone this morning... Not sure what can be done now. Even if they give me a new one, it is useless.... For those who has pasted their new screen protector, don't waste money first, I think there is quite a number of bugs. I use my phone quite intensively and while travelling. So, maybe that's the reason why I discover so many problems.
Abyssal.Xuan
To change the badge settings, go to settings > notification > apps icon badge > badge display mode > select unread messages
Hope this helps!
Abyssal.Xuan
Just realised I have this too. Thinking if I should call hw tomorrow to check ):
Pictures taken from Reddit post here:
https://www.reddit.com/r/Huawei/comm...ve_a_glue_gate
exact same yellowness for my phone. More obvious when when using phone in the dark with brightness at 0.
The bottom pic, get a black picture, then turn your brightness to maximum. I got similar results. yellow blobs ):
I'm sad that this is true but I guess there'll always be bad batches. Hopefully hw can help!
In case anyone facing the same situation.
I called HW hotline, they told me to go down to their technical centre AKA 313 Somerset store for a walk in consultation. Will probably do it in the next few days. Will update again!
eWinter
The Case look interesting.. U may wan to factor in the SP or TG as this will add on to the dimension..
Do keep us update once u rec the item ya..
Thanks
sure I will let you all know when I receive it (probably in 1-2 weeks time)
Shopee state will ship out by 2-Nov I guess is from China. I had the SP on from Xgear @ Waterway point. I just want a casing that can show off our huawei mate 20 pro 's back and yet have some protection..
lol hope this is the one.
Skyy
Scratched alr.. Dun think its corning glass..
your scratch is the oleophobic coating scratch or the glass scratch, very different thing wor. when u run your fingernail across, does it get caught in the scratch at all?
eWinter
tbh if want to get black colour they might as well choose other model. I believe the main reason why 99% of us went for m20pro is because of the outstanding colour LOL~ or at least is just me :p
leon0079
Anyone tried the film protector from Mobile Hw at bugis?
Sent from S8 using GAGT
