Xiaomi mi pad 4
tohtzeer
I applied for circle life $0/mth plan that comes with 1GB data and some talk time.. It works on my mi pad!
Not sure about the difference data and mobile sim. Should be the same I guess. Yes all my sim cards are mobile sim.
keith
hi,
can anyone help to check if you have the "Security" app in your 4+, and ver.
thanks
plustwo
this china rom is complete trash if you're trying to use google assistant.. the permissions keep resetting..
imacbie
well, technically, the device is not released outside china, so only chinese rom available..
China.. where google is not their most friendly partner. :)
hey, they've got Xiao-Ai AI! :)
Slowdown
Someone on YT demo the ability to use typc c headphone. However his mipad 4 was on MIUI 10 beta and not stable MIUI 9x. Either you wait (like me) or you can explore putting the beta rom which I believe require rooting. I dun know how to do all that and thus I wait patiently.
How do we use the usb type c to listen to music ?
The_Red_X
Hey guys, just gotten my mipad4. Wondering if it is just me that is always experiencing those "permissions/privilledges"required by apps (eg, anitivisrus etc) always gets resetted and turned off again after a short time.
Is this normal on a mipad?
Chalanxe
Very common on miui cn. Turninng off the miui optimization don't work sometimes too.
kommissar
Checking for update of MIUI
Hey guys, I just got a Mipad 4 with global ROM and it works perfect, just that when I tap on 'MIUI version' under 'My device' in Settings, nothing happens. So I wonder if I can still check for updates. It is currently MIUI 10.0.5, by the way.
Is it the same for yours??
jackycar
Lol its not global rom, its fake global rom which is CN rom. Closest u can get to global. Is EU Rom
cscs3
Because is not a official global ROM.
jackycar
any lobang for case and glass protector for mi pad 4?
My advice, buy the original case from xiaomi. Its super slim, build super nice.
The fake ones, when u open the case and flip the cover onto the back side, the magnets aren't calibrated properly so it puts the screen to sleep despite the cover being on the back side. No such issue with the original.
Bought from Ali press here:
Original xiaomi mi pad 4 plus Smart Case tablet Frosted shield MIPAD4 PC PU Leather Flip Cover MIPAD 4 4PLUS Sleeve shell 8"/10"
https://s.click.aliexpress.com/e/bexORbQu
(there's a slightly cheaper seller but that one has no reviews to verify authenticity) -
