2018 Google Pixel 3 and 3XL...πŸ˜—πŸŽ‰πŸ˜΅
Shinji_U
I think Pixel 3 XL is more or less confirmed to be using Samsung panels. Only the Pixel 3 is using LG?
Sent from Google PIXEL 2 XL using GAGT
kazekai
See my post above. Someone is claiming that the panel in pixel 3 can be from Samsung too? I'm not too sure of the reliability of the apps he/she was using to test
paul02
I think a lot of people are getting good panels though, just that the odds of getting a bad one is higher than what is normally acceptable (at least that's my opinion la)? But yeah, for a phone at this price tag, it's not great that consumers have to deal with this. Even if they can get it RMA/replaced if they do have issues, it's just a sucky experience.
But regular consumers who have doesn't frequent tech sites, reddit, or forums, probably won't even know about this anyway. So in the end, Google might not care. OR, it could just be like "first batch issues". And it'll get more consistent in the future. who knows. haha.
Odds look pretty high, Google should spend good money on vendors who can supply displays with little variance or error (ideally <2%). That means they will have to spend more though but this is why consumers pay the premium for such phones after all.
Shinji_U
Would it be possible for both LG and Samsung to be supplying screens for Pixel 3? I think that's what the other guy is asking.
It's possible but unless there's more visual evidence it's just pure speculation on Samsung part.
laughingPANDA
Mine coming on November 8, just black 128 GB with free Pixel stand from SingTel. Hope no delay. *********
How you know it's November 8 ah? Was yours delayed as well or you just ordered? Haha.
Sent from Essential Products PH-1 using GAGT
Shinji_U
When I ordered it asked me to select a date and time. Earliest is November 8.
Elysium87
help anyone?
i tried to transfer my photo from my lg v20 by transfering it to pc then i connect my pixel 3xl to pc, i try to transfer file from pc to pixel..got problem, keep cannot trf
i did a factory reset on my 3xl to enable the data transfer which is only in the begineeing. i also cannot try, keep fail. i follow the pixel step, then keep next, at the last page which is for the file transfer, it says reconnect cable
any other way to transfer?
kazekai
Yup it's pure speculation. If we can see some people get Samsung, and some get LG by using the apps to identify the display, it might lend some further support to this claim that pixel 3 might be using both.
After all, the set that was tore down in the video that shows the LG display was only 1 set? Again this is just speculation, and my wishful hoping that some pixel 3 non xl sets are using samsung displays.
HMAN
Unit received.
Delivered in less than 48 hours of ordering.
Alexz_Hong
help anyone?
if you have a dual side thumbdrive (USB-C & USB A), can use that. That's what i use for music anyway. I used to use Android File Transfer app on my mac, but it's a little buggy sometimes. Some phones just does work.
Oh, inside the packaging got a USB-C to USB-A female adapter right? That should work for regular thumbdrives too if i recall.
BlackCube
eh, want to check hor.. using pixel upload to g-photos will be free right. so what's the best way to upload those existing photos inside my g-photos ah?
get all existing photos from cloud, put inside pixel.
delete all existing from google photo (cloud).
then upload from pixel?
or there's better way?
Aikon
Wow Google delivery seems disappointing though. Heng ordered from starhub on Nov 1, delivered Nov 3.
The camera is disappointing though....the color seems off . Example Japan Home logo is cyan instead of dark blue.
Aikon
Is there any way to adjust the settings for the camera? Its also producing darker than average photos. :(
Alexz_Hong
Basically you want o free up space? So those photos on your G Photos uploaded at original res?
From what I know no choice but to download and reupload through Pixel. If not won't count as free upload. I did that a long time back when I got the pixel. Tedious, but no choice. If you have it in albums already, easier to do album by album. But of not, and everything is just there... Can try using Google Takeout to download everything one shot.
wizardmao
help anyone?
The initial data transfer? I've never used that. But does that even work for PC -> Mobile? I thought its for Mobile -> Mobile
Alternatively do the old school way of transfer by copying from PC to Pixel after initial setup etc via file managers. Or upload to any cloud storage of your choice and download from Pixel
