1982-1994
- Oct 10, 2016
sell off the m20 and get the 20X
If the 20x lasts longer, I will.
I have to compare both first.
Me. In fact my wife went for the Pro while I went for the regular Mate as I'm not a fan of curved screen but one thing I noticed is the ultra wide angle on the Mate 20 Pro has better distortion control than the regular Mate 20 and generally the photos came out more detailed and sharper on the Pro. Now tempted to switch to the Pro just for the camera difference.
it definitely will. if it doesn't then there's something seriously wrong with the X where 1000mAh more doesn't translate to better batt life.
wah i haven't buy...don't tempt me![]()
Hmm mine about 3hrs only8-9hrs, light usage.
I think really have to see what is more important to you. Regular Mate 20 has a much bigger screen but the color and contrast is so much better on the Pro cos of the Amoled screen.
Don't be tempted!my main needs is camera, though the non pro camera actually suffices
ya i do light the colour and contrast on pro, but the stupid curved screen![]()
Sent from HUAWEI Mate 20 Blue using GAGT
Don't be tempted!![]()
Posted from PCWX using SONY SUMIRE
yup it really depends. Personally I like 20x but the size can be a little big for me at least
Yes I am holding a rooted max 3 anyway which can hit average 20hrs. Ever hit 25hrs SOT on a rooted max 2.
The reason why I got M20 is I was skeptical on its battery longevity as well as its 7NM chipset.
All these despite I knew that bootloader of huawei phones nowadays can't be unlocked.
Is it when u have a lot of apps installed even when u don't use them they eat SOT? I have a lot of apps that I don't use (but keep just in case), and I disable background on them
You have to take into account that the m20x screen size is 0.67" bigger too.
