Third party Apple Pencil would just be a normal stylus and not have the all the functions right
Except to get cellular Data for using this IPad when no WiFi, basically no other advantage for getting cellular version right?
No difference albeit the cellular modem.
Thks Mate. I better same this money to get higher capacity
Yup that will be a wiser choice unless cellular is a must for you.
Absolutely not. Like any Apple new invention, the magnetic holder and charger will only be compatible to the Apple Pencil
Anyway, do any of the retailers have the pencil and smart folio in stock?
Looking for temper glass now
adiBOY, about the AppleCare, better to have it??i always buy it with my iPhone but this is my first ever IPad, does it require you think?
And I think I won’t be changing this iPad like the way I change my iPhone, 256 good enough?
For iPad I would recommend getting AppleCare+. You’ll never know what issue will surface with that level of thinness or you might just drop it accidentally.
No Apple Pencil?
Got q at Apple store
Ipad Apple care 189 dollar I think quite worth it. Anyway you got 60 days to consider.
Just now I went to pick up got queue. Not sure if there is now.
