Bought Dome 3D full curved tempered glass in westmall kitty mobile, at $59.90, included installation. Not bad, compatible with the original Huawei case. Fingerprint scan works.
Smlj 59.90 screen protector? Made from crystal ah?.....
lol.. me too! now that Huawei has responded (although not officially to the press), it seems that the problem will be gone in a couple weeks' time.
but just wondering if should just wait for p30 pro... in March? hmm.
Anyone using the casing and screen protector that comes with the phone?Quite cool to package them w the fone, provided one uses it haha.
MaTe 20pro do not hv sp pasteDoes it comes with sp?
Normal Mate 20 had a screen protector pasted. Those normal soft type.MaTe 20pro do not hv sp paste
Case only. M20pro dont have SPAnyone using the casing and screen protector that comes with the phone?Quite cool to package them w the fone, provided one uses it haha.
How much is the Redwhitemobile tempered glass?Just to share. For my m20pro, I got uag plasma case from p2o mobile can use together with the full adhesive tempered glass from red white mobile. Uag case this time round has 1mm top and bottom clearance and doesnt push up the tempered glass.
Will monitor for a few days and update here.
Sent from HUAWEI LYA-L29 using GAGT
Anyone know mate 20 not pro will have the 3D scanning soft you features?
Sent from HUAWEI Mate 20 Blue using GAGT
No as it does not have the hardware to do that....
my 1st day at work with huawei mate 20 yesterday and was very pleased with battery life. With sync on and long SOT, I think it was around 5~6 hrs, i lost only 50% battery life after 12 hours.
Lost 2% battery life after 1 night of sleep!
What do u disable in the night when u are asleep? I'm using mate 20 non pro too and every night i lost about 5% with approx 8 hrs of sleep. Is this normal?
Thanks! I got mine from MobileHardware but it has black borders. Thinking of switching over to the redwhite one$30 per pc.
Launch HiCare go to Me then settings then change the country/regionAccidentally press the wrong language for HiCare apps. Does anyone knows how to reselect to english again?![]()
I've already Manually set app launch to untick all apps except Messaging ones. Anything else I can do? Uninstall apps?
