Huawei Mate 20
ayuluv
I unplug it.
Be awesome like me :D
jokes aside..I am connected to the wifi at work so that is one big difference I forgot to mention :o
I do game clash royals and brawl stars.
It's 2 hr 40mins currently at 65%.
33% batt after 2 hr 40mins of SOT..7hrs since leaving home.
hmm thanks.. i played dbkr as well as kof AS
but my numbers dropped massively
ayuluv
hmm i need to monitor then.
Btw do you guys display time on screen off or just off it?
I do have wifi when am at home though.
And also i realised my whatsapp notification, it appears and after a while the sound then appears with the notification again. Does anyone has the same issue as well?
1982-1994
Bro do you have some guide or manual on what you normally do to achieve your godlike sot
Oh easy if you can be like me, who never logged in Google. And I disabled Google apps except play services which cannot be disabled at all unless root.
How I sync? Store my backup files on Dropbox.
And I don't play games.
WhatsApp is not installed on mate 20 anyway since I have another spare phone.
Stop using Facebook standalone app, log on via browser instead.
And try brave or kiwi browser ,they are battery friendly but I'm leaning towards brave.
I'm using aqua mail as my default email app.
Business calendar pro as my default calendar.
Anyway, I am a light user. Just purely surfing browser and listening to music.sometimes stream online video through 4G since I have enough data.
1982-1994
After 10 days of usage on mate 20, the battery life is kinda on par with my rooted xiaomi max 3. Standby time ,the latter should be better.
So if mate 20 can be rooted.....
1982-1994
It's only when I place the phone in my locker at work, the battery drops 2% every 3hrs.
Till the last drop of battery left , the SOT per % is an average of 11-12mins.
A rooted Xiaomi max 2 can hit 17m SOT per %.that was the highest I encountered.
ayuluv
so far huawei will be issuing its 10k mah powerbank for affected customers
Abyssal.Xuan
I unplug it.
Be awesome like me
:D
:o
33% batt used after 2 hr 40mins of SOT..7hrs since leaving home.
Do you get jitter lag when play brawl stars? Like move the character halfway the fella standstill then need to flick the movement stick again :s13:
id0n0van
My set has no issues yet, I'm thinking if I should just head down to the service centre to get my set replaced when the new stock comes
maur_james
FYI, I changed the tgsp at WWP, fp sensor is still hit & miss (more miss than hit).
So no perfect solution yet...
James Tang
About the standby hours,
Try charging your phone to full, just leave it there and don't use it. The standby time will just increase.
Having to say that, SOT is definitely affected.
Low usage = high standby time.
High usage = low standby time.
Edited: You can't have best of both worlds.
The AI look at your usage pattern and estimate the standby time.
I did an experiment: dont open any games... standby time over 40 hours
Once I started playing games (eg SIM CITY, SkyForce reload) and keep it in the background.... the standby time decreases to under 15 hours. However, if the the rest of the day I don't open and play games, the phone can be used for over 15 hours and still have 40-50% juice left after.
James Tang
For those looking for NM card and the reader, you may want to try Aliexpress. Just got one from there. They have 256GB ones, left below 10 in stock.
Decided to give it a try (hope genuine) and if not, can get full refund. So far purchasing from Aliexpress has been good
id0n0van
C'mon, I'm not that cheapskate.
My device is using LG panel, batch 51, and I haven't had the issue on my device yet. I don't want to land in situation where I've invested in a premium TGSP and then I need to change my panel the following day.
The device has been so far so good, but it's only Day 8 and who knows I might get the green display issue on my set?
typical ppl lol he just want new phone
