Huawei Mate 20
jlekssp
go to setting to set it, once your phone is move, it wakes up, no need to double tap...
Thanks for your help, I am using mate 20, that why I am looking for app that can wake up the screen by double tap on the screen, but seem like don't have at the moment which you are right. The only workaround by using face unlock, I can wake up the screen without a tap on screen but I don't know how safe is the face unlock since it is not 3D face unlock on mate 20, lolx
As for the double tap to screen off, I found one app "doubletap to lock", seem like working but will test it out further
kyleongwl
local sets means what?
i just don't want to get sets that are sold to them by customers who recontract :s13::s13:
Its new set..
Normally 3rd parties are selling lower than RRP.
Mate 20Pro shd be 1150-1200.
RRP is 1348
ZechsYoun
Hey everyone, I want to ask if anyone had activate App twin and App lock function and face the same issue.
I currently have App lock on, and for App twin I activate another WhatsApp account, but in App lock, I am only able to lock WhatsApp, the App twin WhatsApp cannot be lock.
Anyone else face the same issue as I do?
Lobaba
Do you get jitter lag when play brawl stars? Like move the character halfway the fella standstill then need to flick the movement stick again :s13:
that one due to the game not performing well on any wifi connection...shouldnt have problems with 4G though based on my experience with both samsung s8+ and mate 20
The standby for mate 20 is rather bad. Can't find the reason.
the AI thinks you should use your phone more :s22:
The lack of OIS in all 3 cameras, sensor size is a step down. Only upgrade is the wide angle lens which takes good macro shot.
Screen wise, I'm pretty used to OLED and as external speaker, mate 10pro is better.
I came from s8+, seems quite ok with the loss of OIS leh
Screenwise am also used to AMOLED but fear not..the LCD screen is very good!
getting mate 20 tomorrow :D:D
join the small club!!
petricnah
:s13:
:s13:
You need to trust the shop(buy from raputable shop) , make sure is it a sealed set(hope the shop don't repack it) or buy from HW shop.
:s13:
:s13:
s-ghost
High Honorary Member
now considering buy from airport or redwhite
s-ghost
:s13:
:s13:
ya I only scared they reseal it
i somehow just don't like the idea of using a set that someone played before with and sell it to them :crazy:
Abyssal.Xuan
:s22:
I see. I can't not play on WiFi at home because my reception is horrible where I live. Hahaha.
yhw22
Anyone using app to schedule WiFi on off?
Sent from Sony G8142 using GAGT
