i have a strange thing going on...
i put in my starhub card.. and then it is not able to register on the starhub4g network.. even manaully...
then i turn on my wifi to use my home wifi...
then the starhub 4g signal is lock on... and appears on the tablet...
then when i turn off the wifi... it's gone..
anyone knows why?
did nothing to it.. just use as per right out the box... just went to the link provided and download google play ...
i tried the card on my ipad.. and it works dfine...
any ideas?
I bought the wifi version but he send one w the SIM card slot. Doesn’t it mean got LTe or not
EU rom has google play?
U can't use it for normal telephony. The sim card only meant for data and sms, not to make phone call unless u are using Whatsapp call.hey guys, would the mi pad 4 suffice as a simple phone for my dad? currently in the market looking to replace his galaxy tab 3. he uses it as a phone, the big screen helps. was looking at apart from the new galaxy tab series, is there any other brands/models that are quite competitive in terms of specs and price, with similar screen estate.
TIA!
TIA!
Is it worthy to get MIPAD 4? Or should I get other tablets like Huawei mediapad?
Understand that this is on China rom,can Google play store and youtube be installed? Language can it changed to eng?
Planning to get the 64gb wifi version, saw on qoo10 that it's abt 315
Hi, anyone managed to hook up your mipad to tv? How is it done, via Chromecast ok? Or need USB-C to hdmi cable? Advise needed. Thanks
how to access developer option on mi pad 4?
Couldn't get mine up via wireless display too.
