Zero1 Mobile discussion thread
tellim
Using zero1 since day one launch....im happy. Those picking bones one should just avoid... dunno what's the problem...want cheap want good.
cheeeeseee
Having intermittent connection the past few days. It shows a no-data warning in my games at times and is really annoying. Below are all the speedtests I did just to show how intermittent it is, they're about 1 min apart each. These tests were done when I only use 700mb of my plan so far.
https://prnt.sc/lgvdyq
What's interesting to note is Friday was when I first picked up my new SIM card for the auto-roaming feature (have not changed yet).
I'm on the $19 - 3GB plan, never had this issue before. Will run tests to see if my throttled speed after 3GB has been reduced. Anyone having similar issues?
kottty
keep us update after 3GB ..thanks
Sent from Xiaomi MI MAX 2 using GAGT
WestGuy
I'm on the $19 3GB plan and still using the original SIM card.
I can confirm that i am still consistently hitting 1mbps download speed despite having exceeded more than 5 GB of data.
kottty
me excess 30GB still get 1mbps ..
Downloader
I asked questions about roaming and wanted to share this with existing users before 15/8/18.
Thank you for contacting Zero1!
Yes, you need to change new SIM to have roaming feature available. Alternatively, you may wait for next month to have the roaming access ready (without having to change SIM).
There is no need to change SIM again if we release data roaming packs.
Hope this clarifies.
I'm on $19 3GB early bird plan. Emailed them 2 weeks ago but yet to change sim. Wasn't told can choose to wait for roaming for current sim card without changing. So is this confirm or still valid?
Chae Yeon
01 so far has been good to me.
Throttled speed is able to play maple m with no problem doing expeditions.
I'm impressed.
