athenodorus
- Dec 9, 2005
Anyone tried before rwm glass and wwp one? Which one better overall?
Anyone tried Plasma and Monarch UAG case? Worth the $20 diff?
Sent from HUAWEI LYA-L29 using GAGT
Yea it is, when it was gripped by the car mount phone holder, my screen actually got 'touched' by the grips so end up when I try to zoom in on google maps, it zoomed out.The given one like quite soft along the screen. Lol doesn't feel solid. Will try out.
Why 3rd pc?I'm on my 3rd pc tempered glass with uv glue, saw them remove twice, wuite easy to remove. No issues.
i tried WWP. fingerprint sensor obviously is affected despite all promises. however still a good job overall so now i disabled fingerprint and use facial to unlock.
not sure about RWM.
not sure about RWM.
How much was it at WWP?
My RWM one also affecting my fp scanner. And it has a scuff so I’m going to try the wwp one and see if it’s any difference. It’s much more ex and not loca type. They claimed won’t affect fp but I’m skeptical about it. The packaging also looked like some tiong generic ones.
Last resort is just use film next time.
The side borders can be an eyesore ya esp when using with the default case. Hais. Somehow the fp works much better than my RWM leh. I still find it ex for a generic non Loca glass.i dont recommend WWP, unless you plan not to use fp. but even so, the black border is an eyesore as well. for me, i would just put a cheaper film one until there is more promising solution available.
Anyone tried Huawei m20p silicon case? Any review compare to the free case given?
I suffer the same fate as you, not as lucky as some of them here.i tried WWP. fingerprint sensor obviously is affected despite all promises. however still a good job overall so now i disabled fingerprint and use facial to unlock.
not sure about RWM.
IMG_20181113_155000 by TangKF, on FlickrHow much u bought it?Managed to get a 256GB NM card from AliExpress
[/url]IMG_20181113_154814 by TangKF, on Flickr[/IMG]![]()
Seller is very responsible as he actually sent me a PM on how to cut the packaging of the NM card without damaging it. Apparently there have been cases when the card is destroyed.
