OFFICIAL ONEPLUS 6T!
SuperDecker
I read the oneplus forum just now on the fingerprint bug, it seems only very few ppl had this issue. If its a software bug, I wouldn't be very concerned unless it's the m20pro green screen bleed issue. Lol
so it went thru but later on... it didn't work with her fingerprints anymore....
wonder if i should wait for the later Oxygen OS version instead.
KeYoKe
Maybe your wife is your long lost twin and both of you have the same fingerprint! �
Haha, Just kidding bro �
Hahahahaha wahhhh! Like that cannot la. All wrong liao like that lol
Sent from OnePlus ONEPLUS A6010 using GAGT
anodiz3soh
Oh.. interesting.. I will try on my set later. My set has arrived this afternoon. Looking forward to it.
KeYoKe
Just a theory but could it possible you had face unlock enabled and you were within the camera's view?*********
Nope i dont use face unlock bro hahaha
Anyways just a tip fo fingerprint unlock for 6t. Pressing firmly and slightly harder will increase success rate.
If u dont apply a bit of force, quite difficult to scan
SmallLittleBoy
Received my set today. Spent a few hours setting up and transferring everything, especially whatsapp data which took really long lol. Loving the new phone so far. :s13:
KeYoKe
Which color did u buy bro? Local or export set
Gixxerfied
I setup the phone from scratch. Manual transfer some pictures over although they are in google photos..Then restore WA backup.
anodiz3soh
Mine came with a 2pin charger. Read from somewhere,it says it is 3 pin.
Other than that, it is quite good. Now doing the setup.
Gixxerfied
Mine is also 2pin charger, no issue with export set for me and with the charger since i'm using intl socket plugs at home.
KeYoKe
No issues for me too. I bought a 3 pin dash charger from 131 for 19.90 lol
macburger09
Just got my from 131 this afternoon ...
Just to check charging now no notification lights, need to wake phone to check ?
It doesn't come with pre-installed screen protector?
anodiz3soh
Nice bro enjoy the phone man. Im loving it too
Means yours is export set from china bro
Yeah. I know that. When I opened up, the Chinese words there, I know it was China export set. Anyway, it is all good.
strikefreedom_83
yes Oneplus 6t have no LED notification light but it came with pre-installed screen protector. Yours doesn't have?
