Huawei Mate 20
deadrick
Bought the black one, the coating that made it smooth at first touch is frustrating. Slip out of hand frequently, but causes friction against fabric when placing it in fabric (skinny jeans).
After a week, there's visible difference of coating at different contact points of the case. Conclusion, stay away and save that $28 for something else. Of course disappointed at how it compares to Apple's silicone cases but between $28 and $59, its a comparison of apple to oranges.
Thanks man. save my $28.
And the hunt for thin n protective case continues. Something lighter than spigen w protection. Lol.
1c3_5n0w
got my mate 20 today. on screen time is crazy and the panel is great.
Sent from Samsung SM-N960F using GAGT
NiNiaMa
Yes, it did stated online when i ordered. I called cso and **** him. Then he went to check with his manager and they got back to me promise that my delivery will come with voucher
Sian buy online no free wireless charger redemption voucher also. I thought it wrote free redemption gift during check out.
shingo
Hi anyone using Mate 20, found that the sound setting (vibrate when slient) will switch back to on even when it is switch off?
The screen auto adjust brightness display will go back to on even u off after u reset the phone?
Anymore bugs u guys encounter?
gavthang
any one has experience with Explore Mobile shop? are they trustworthy?? cos they only do online.
Please advise
Cos i thinking hard whether to buy from them....
gavthang
Please advise
cos they selling sealed set at 1100 with wireless charger!!!! very tempted to buy from them
fabianshc
Glass Protector
Hello guys!
Am thinking of getting the Mate 20 pro during SITEX next week.
Would like some recommendations on where I should go to both purchase and install the glass protector.
Anyone here have used full adhesive protector on their mate 20 pro? Can share your experience with it? Or if anyone can recommend something better?
Thanks!
fameasser84
What screen protector are you using? I understand some of them can't be used with UAG.
Good question. I'm getting my handset replaced due to screen issue. Am waiting for review as well before getting a SP. may go naked eventually.
Aikon
Anyone having similar issue with me? My Device Info HW showed two different batch number of my touch screen LG panel. One week ago it was batch 43, today it became batch 51!
Sent from HUAWEI LYA-L29 using GAGT
Yes the latest firmware update from Huawei caused this I believe. I noticed it after I just updated my set today. 43 became 51.
