[IP Cam] Xiaomi IP Camera Xiaoyi
cosycatus
hey, is it possible to have this camera record in real time to a hdd on the wifi system in real time?
As in camera place outside home, once it detect motion, it will record to the hdd on the wifi network INSIDE the house, so that even if someone destroy the camera or makes off with it, i've capture the footage
xtractor
xsoldix
Check out dafang hacks.
FinchGuy
hi guys, i managed to scan the QR code to my dafang and when it tries to connect to network, keep getting timeout error leh... my router is less than 2m from the camera ... so not sure why
Same problem with my Xiaofang even after I set location to mainland China. Anyone knows how to get around this? TIA.
Baggio10
Wish to find out whats the difference between Dafang and mijia 360 cam other than the shape and size? Which is better?
oAkEn86
Anyway to view multiple xiaofang cameras which has password at the same time in mi home app?
Earthling
Just bought a xiaofang camera intending to do AP mode for offline recording. The app and the xiaofang itself seems pretty buggy, connection keep dropping and connection errors :(
icyflame
I am trying to find out too. Small view allows me to view all the 3 cameras but they are too small. Large view can only view one at a time
ses009
I have 2 Xiaomi 360 home camera. One in living room near router, the other in master bedroom. However The one at living room always lose connection and show offline while the one at bedroom has no issue. Any idea what issue could it be? Strange because the living room camera is just above the router.
IloveEmma
Hi All,
I have two yi cam 720P. It is from China based on serial number and try to flash china firmware.
It turned steady blue in the end and say wifi connected but it doesn't appear in the apps. Tried Yi camera app and mihome but both the same. Any idea what is wrong?
Sausage
The dafang USB slot is quite narrow right
Normal USB cable cannot fit
Chuck Norris
Hi All,
Wow I have the same issues too... Can anyone help? :s12:
tzxiang
I am a student looking for xiaomi yi 720p 11cn or 22cn versions. I am working on a project. Anyone keen to sell? Pls contact me. Tks.
ABuNeNe
Need to place my dafang camera very near to the router and it's wifi strength is always showing 0%. Could mine is a faulty set?
