Huawei Mate 20
jlekssp
are u plugged in directly to your wall socket or thru a cable extension? Try it on the wall socket and see how it goes.
Hi guys, just got my mate 20 yesterday. I noticed that when I charge the phone, it only display "charging" instead of "super charging" on the lock screen. Is it just mine or it's like this for everyone??
Geros_Peters
Mate 20 does not have supercharging, only Mate 20 Pro has supercharging.
I'm not 100% sure but thats what I read online. I might be wrong though.
knave
All mate 9 & above are super charging.
Only the Mate 20 pro is extra super charge
Posted from PCWX using HMA-L29
kirium76
Seems like they limiting the stock to the telcos. I've been waiting for the Singtel one for a really long time.
Maybe HW is doing internal QC first before releasing the good stock to the Telco?I rather wait for the good stock rather than buy already then the hulk emerges after a few days lo.
Sent from Samsung SM-N950F using GAGT
jlekssp
i realise when you delete an email, the transition is not smooth. any way to improve it?
kirium76
You can consider this clear uv glue screen protector from GW. I got mine applied today and I have to say its really good though a bit expensive. No issues with fingerprint sensor nor casing pushing out the edges.
Huawei Mate 20 Pro UV glue glass for S$38 https://sg.carousell.com/p/199576042
Can attach the Pic of the applied glass on the phone?
Geros_Peters
Ok, my mistake, thanks for sharing and correcting my error.
Extra Super charge is due to the 40W charger??? The 40W Charger is included inside the box?
Geros_Peters
flyingeagles
I just got my Huawei ytd and I noticed the green hulk evolving now.. What should I do? Any one has successfully replaced their phones..?
Sent from HUAWEI MATE 20 PRO using GAGT
