Charlie_Zhan
- Nov 17, 2013
VPN will help increase your ping.Will VPN helps the PING?
guys, anyone subscribe to the games?
Also, is there anyway to change region? i dont know why mine is in europe instead of USA.
What does EPG refers to?jus to share..managed to get the homerun and antenna.
tried 3 app
1. live channel ( using hdrun and aurora tv as source) - somehow subtitle dun work. no epg. if use aurora as source, for some reason, first load will not load channel. need to switch channel upon load and it will be ok.
2. hdrun app - same as above. no epg
3. aurora tv - got epg and subtitle. so far think this is the best option.
only thing is aurora tv is some what an subscription app.....so not sure how it works...so far haven seen any ad yet. maybe need to watch long duration den will have ad....cant confirm.yet so no time test.
electronic programme guideWhat does EPG refers to?
Is there any channel for EPL?
Thanks for the info. Was thinking getting VPN service , any to recommend?Using VPN?
Ref:
https://forums.hardwarezone.com.sg/...ch-english-premier-league-online-5441921.html
Or some random website/apps
https://forums.hardwarezone.com.sg/...-way-watch-epl-live-good-quality-5935837.html
A few other references.
https://www.ivacy.com/blog/watch-premier-league-online/
https://just2me.com/2018/06/23/how-to-watch-world-cup-in-singapore-for-free-yet-legally/
Disclaimer: I am not a soccer fan and I do not watch EPL, just carry out some research in VPN recently.
Did anyone try installing Starhub Go app on the shield? Does it work?
wah, i havent even update yet. now scared.
It's a hardware tv tuner. Basically, you need to plug in your TV antenna and power and LAN cable. Here is the link where I bought mine.
https://shopuk.silicondust.com/shop/product-category/hardware/?scrollto=483075
Yes it can watch live tv on 2 devices at the same time since this is a dual tuner. It can also watch live tv while recording another show. If you need they also have a 4 tuner version but is more expensive.
You can watch on your phone or tablet also. But keep in mind, this works only on local network. If you want it to work outside your home network, you need to set it up with Plex Server with a Plex pass.
Hope I answered your question.
Hi sorry do I need a VPN for that?
Thanks Xiaofan, u have been v helpful. Besides gaming, I'm not sure what exactly would be useful if I get this shield. Not sure if it's sensitive to ask how to I get Netflix us to work here
