e-Remote Broadlink RM-Pro
singcheng
can Broadlink control KDK (dc motor) fan ?
went to kdk showroom but the person doesn’t understand what rolling codes are
if can, are there limitations eg certain commands cannot be executed or learnt that i need be aware of ?
TIA
bought a RM Pro+, waiting for shipment to arrive.
will try this out and report back.
medscy
hmmm.. i prefer to have discreet on and off, trying to see if i can get the raw RF codes.
these i believe are called the Broadlink Cloud Codes..
did you managed to do any further research on it?
i have 2 RM Pro Plus device, tried to use one to send to another, abit hard also.. but doable.
if you just need discreet codes, you can use this to generate the RF codes and then get the Yoogee switch to pair with the code. One each for on and off status per switch.
https://dimagoltsman.github.io/Random-Broadlink-RM-Code-Generator/
stiffneck69
Could not use IHP app to control anything since yesterday evening. Scrip error. Cannot even access my devcies, "failed to download resources". Sever down? Anyone else having the same issue?
All is back to normal. Did nothing at all on my side. Most likely server issue on broadlink side.
xenocide
finally its resolved with the latest update
i could add my Yoogee switch, pair to e-Control app and create scene.
Elon Jobs
About time. Honestly, they should test their apps before releasing into the respective app stores.
DingDang51
I had this script issue and thought l had to recreate. Deleted my sound bar from ihc and now l can no longer find the TV template to add the sound bar. Can anyone help? Tks
Sent from OnePlus A3000 using GAGT
medscy
On the main page of the app, tap on the Device tab at the bottom. Tap on your RM Pro and it will show a list of equipment managed by your RM Pro. Then tap on Add Appliance. The option for the TV template will appear.
thelalaman
Hello everyone, first time posting in hwz. I just purchased a broadlink and planning to set up my ceiling fan. I do have a problem is that in my living room, there are two ceiling fan in close proximity and the IR remote can control both. Anyone has this issue before and how to resolve it? Thanks!
AndyTan113a
Hi All, just obtain my Broadlink Pro+. Have been trying to link to my old Bose Lifestyle 5 system but doesn’t seem to work. Any advice? Thanks in advance.
galliano
Chanced upon this Broadlink device...wondering if it can help link my gate remote control to Google Home.
Currently using Google Home Hub with Nest Video door bell.
For my main gate, my contractor says its a hard wire connection basically to trigger the lock/unlocking of the front gate OR its a radio frequency.
BenBen010103
I am quite fed up with my broadlink tc2 switches due to the number of faulty units despite me buying extra just in case. The problem is either totally no power, switch auto turn on/off by itself, light flickering, etc All the extra switches have been used up and i think its time to look for other brands.
Have read through the pages and saw quite a few brands namely funry, e-touch, livolo and yoogee. Will like to know which one is more value for money, and able to pair up with rmpro/alexa? I do not need 2-way, i just need a maximum of 3 gang, no neutral wire, and which one no need install extra capacitor(for flickering problem)?
Elon Jobs
I’ve been using eTouch for 6 months plus and so far, so good (touch wood). It checks all your boxes- 3 gang maximum, no neutral wire, no need for capacitor. I suggest you buy it from the Broadlink distributor on Carousell- she does exchanges in case the product breaks down prematurely like your TC2 switches.
evq
Hi, I only managed to get broadlink to learn on and off. Could
You guide me on fan speed and other buttons? Thanks!
i have the same problem, only On & Off.
And cant get it to learn my Mitsubishi AC at all.
Elon Jobs
Same as yours in the video. But my fan model is U60FW. I using google
Home with pro+ .
Okay, need some background in case I reply you with the wrong information. On the IHC app, you are using what template for the remote? Lightbulb or user defined or?
