Android TV Box
In short official box run the the androidTV os and not a tablet version of android. Official boxes also does Chromecast, DRM for 4k netflix etc, Google assistant built in and have the curated play store.
Unless u are a geek and want a rooted box for installing adblock and stuff or want to run Linux on your TV box stick to the official boxes (mibox & Nvidia shield)
Good summary.
But I will even say forget about Android TV altogether (even Mi Box and Android Shield TV) and subscribe to SingTel TV and StarHub TV for those who think side loading apps is difficult.
ktyandkyc
Good summary.
Oh if then what's really the main decision factor to land on say Nvidia shield versus Minix?
If I'm a geek, I should go for Minix? But if I want official support for Android functionality like Chromecast, go shield?
No, the Minix is overpriced, go get the Nvidia Shield TV no matter what if you are only deciding between the two.
Linus Tech Tips’ review of the Mi Box S
US$60 Mi Box S has built-in Chromecast Ultra (4K) functionality which costs US$70. Nice one.
gregory_choo
[YOUTUB E]on5I4KJfulw[/ YOUTUBE]
Nothing new.
The older mibox international version also has built-in Chromecast Ultra (4K) functionality.
ktyandkyc
@xiaofan,base on the top10 Android box spreadsheets, how's the performance of Minix u9 feature
csc12345678
Hi
I wonder if your streaming breaks in the evening ? Seems to be fine in the afternoon.
Thanks.
csc12345678
Which box? Which app?
Posted from PCWX using EML-L29
Testing a M8Spro. Think it's not the app, cause via browser or player like MX Player, same. Probably the internet ? Or my network settings ? Or the server selection ?
If you use WiFi, then switch to wire to test. There might be multiple version of M8S Pro. Is yours from MeCool?
Even from MeCool there are different models.
M8S Pro, Amlogic S912
M8S Pro L, Amlogic S912, unofficial Android TV
M8S Pro W, Analogic S905W, unofficial Android TV
This may be related to your internet and not the box. You can check if your other device have the same problem with the same app or not.
csc12345678
I'm using wire. I can switch to wifi but I thought the TV is between the box and the router, it may cause interference. I'm using the Pro S912. The internet is actually not gigabit, only 100MB/s.
I've used the router app to monitor the traffice, when it's good, it also not using a lot of bandwidth. So I wonder anybody else having this problem, if it's due to the internet, others would get it too.
gregory_choo
are you watch seafood channels? to be more specific, watching prawn?
gregory_choo
no lah... just testing the box. I hardly use it.
what's wrong with letting others people know about the app you used and the channels you watched?
if you revealed them, it is easier for xiaofan or other people to help you to troubleshoot.
csc12345678
Cause I don't suspect it's the app... any way, it's Kodi & IE. My box hardly install any apps, just kodi, MX player, vlc and other non-video related apps. I have a very old TV and I don't normally watch on that box unless we have a few people together. So sometimes, I only on the box once every few weeks.
I think it's the internet and I ask to see if others are having the same problem. I think it's the network. cause it only happens at certain times.
