Apple Watch Series 4
klho001
Actually i think the US version's LTE bands are not compatible with SG.
Singtel runs band 3,7,8 and none of these are listed on the US version
Snoweagle
Snoweagle
deathst
I'm using both latest OS for phone and watch, but I still don't see any 'ECG', just regular heart rate readings.
Aiya never mind one. It is just the same as regular heart rate. No visual for it.
cracker
Hi,
just bought a pair of apple watch for me and my spouse.
may i know how does the walkie talkies work?
we are currently on oversea holiday.
iin hotel we have no issue as both phones were connected to wifi, however at outdoor; both watches kept giving “.. can’t connect to the other party..”
both phones are on oversea data roaming and both watches can receive what apps or line message alert but this should be due to the bluetooth connection between the watch and phone.
thank you
deathst
Hi,
thank you
Walkie-talkie operates around FaceTime Audio calls. You will need to have your phone with you if you do not have a Cellular Apple watch.
On your iPhone, open the Settings app, then tap FaceTime. Make sure that you're signed in with your Apple ID. Under You Can Be Reached By FaceTime At, make sure that your email address is selected.
Restart your Apple Watch.
Restart your iPhone.
This way the device should also try to connect via your Apple ID Email address instead of your phone number which can change if you are using another sim-card.
xiasuaykia
Hi all,
am deciding whether to get a wifi or cellular version of AW4. Any inputs from your side?
My phone is always with me, only occasionally when i'm away from my table, or when i'm out for a run.
Should i pay an extra 150 dollars for cellular? and on top of that 10 dollars for monthly services?
Snoweagle
Hi all,
I presume you’re on Singtel. I myself have my iPhone at least 80% of the time but there are times when you need to be away from your phone for a while and the cellular feature can come really handy, hence I bought the cellular model.
I’d say go for it and even if you don’t need it now, perhaps in the near future you might and can activate numbershare at any time.
By the way, first 6 mths is free and thereafter is $6.90 from the 7th mth onwards and a 12-mth contract applies. From the 13th mth onwards then full price. Service activation fee is $10.70.
USBThumbDrive
Can i ask for Series 4 cellular, Lets say if i uses a spare singtel line for number share. But my main line is on my iPhone, will the cellular works and pair with my iPhone accordingly ?
Snoweagle
No, the cellular on the watch (eSIM) will only work according to which number you pair with on the phone. If you use your main line and pair your watch in which you will have to activate numbershare from the Apple Watch app directly, it will follow that number.
For your case if you use your spare line for numbershare, then it’ll be just that number.
USBThumbDrive
Despite it being paired with different number (Cause of number share only available on Singtel), but if I pair it with the main phone (main line). It'll still able to function ?
Like the number share its solely use only for the cellular feature?
Snoweagle
Yes NumberShare is to enable usage of your watch without a connection to your phone. Remember this, one NumberShare subscription for one mobile line. If you've two Singtel lines, you've to get two watches with a subscription each.
