TheOutsider
- Aug 30, 2014
Time to upgrade to Mate 20 guys. Its awesome.
But... Huawei CPU still not good enough haha
Otherwise yes it's good. Now shop price can get $7XX d. Not bad.
Why not enough?
This model pretty good for gaming. Saw colleague using.I got mate 20x.
7.2 inch of awesome.
hehe
gonna pass my mate 10 to wifey.
btw, the battery holding power is not as good. is there any chance I can replace the battery for free?
Sent from HUAWEI MATE 10 using GAGT
Nope. Not shibexxx.are you shibexxx?
yes I'm gonna use it for PUBG.
Huawei always release near end of year and they're only able to match the performance of Snapdragon chip from earlier of the year. Just few months away Snapdragon 855 will be out and Kirin 980 will be beaten to ground. Not to mention that Kirin GPU has been lacklustre compared to Snapdragon's offering. Recent benchmark shows Kirin 980 GPU just managed to only equal that of S835 if I remember correctly.
Speaking with my current phone, a Mate 10. Sometimes can feel like it got bottlenecked. Sometimes in games where the GPU can't keep up, sometimes when switching task it will lag and stuck for a second or two.
The AI stuff Huawei been advertising too... There was one review that I read on that earlier defining the AI processing power for the CPU in market. Huawei 980 is just slightly ahead of Snapdragon 845. Next Gen Qualcomm is going to include a dedicated unit. Guess it will then beat Huawei all the way again. Good thing is Huawei advertised it and used it the way it should so the consumers know what that thing is for. Other snapdragon phones like never advertise so much on the AI processing capability. It is also behind in Video encoding and ISP compared to Snapdragon equivalent not to mention that it does something like the slow-mo with software trick rather than having real hardware support.
tl;dr
Huawei chipset is good but not the best. Quite a distance from Qualcomm, even more so from Apple. Enough for normal use but for some advanced users, you will know where the limits are. The pricing for Huawei phones also quite good but not the best best best CP ratio especially when last time Snapdragon flagship chipsets used to be reserved only for the expensive flagships from each brands but now you can get it quite cheap at just like $400 bracket.
I got mate 20x.
hehe
If your mate 10 still under warranty then battery will be covered under warranty.
The battery is actually around 4700+mah. Should be able to last quite long.If your mate 10 still under warranty then battery will be covered under warranty.
Yes. They stated 4000mah in their spec but if you use battery apps, you can see that the actual capacity is much higher.Mate 10 4000mAh right??
