TN panel got pretty bad colors
Alexls
Just bought acer kg271
When i open google chrome on my ips last time, the colour is like grey/slightly blue
Now on this tn panel it looks like a weird blue/yellow and color not uniform
Is this calibration problem or all tn panel look like this?
lifeishard
adjust color to more 'cool' tone to see if it is to your preference? maybe this monitor out of box more 'warm'.
PC
once you get used to IPS, TN will look like shi*. it's hardware limitation so no calibration can help.
MeetYourTea
u bought a 75hz monitor? really cum gong kia.
usually ppl buy TN panel coz of 144hz u buy for 75hz. i rather u get IPS 60hz. 60 and 75 no diff
batniss
U ask so much and open so many threads in the end all you got was... This?
A TN @ 75Hz!?
$250 for a 27" 75Hz va Acer Ed273 curved screen is more worth la.
Alexls
A TN @ 75Hz!?
Lol at the shop look like no diff between tn and ips
I bring home look then realise got big different
A TN @ 75Hz!?
ohhh... now i remember his threads liao........
wwenze
TN usually has one angle (usually up to down) where color changes with angle
Other unevenness is more likely due to Acer than TN
Kepller
IMO don't go for TN and IPS for Gaming, Movie watching and Basic Usage. Only for professional graphics works where you need color accuracy, go for IPS. Other than that go for VA. VA has better contrast ratio than both IPS and TN panel which is very important and makes a big difference in picture quality. The only advantage that IPS has over VA is the wider viewing angle (which is more useful with a TV since it is used for shared viewing among many people seating across the room and viewing from different angles). For PC usage, you will be seated directly in front of your monitor most of the time so why prioritize viewing angle at the expense of a lower contrast?
wadsad
eh really. for all the threads u started, and u ended up with this monitor. :s13:
shin89
I'm kinda glad he wasn't satisfied with his purchase.
trento
Yes it’s possible to see things differently at different places due to angle, lighting etc.
But generally speaking, if ts prioritise color over response time, then it doesn’t make sense to get tn.
Personally im fine with tn cos it was cheaper n im not tat bothered with colors. Seems like now the price gap is narrowed so i may go ips in future
He was worried at the beginning but when at shop he saw no differences so he bought it, u dun understand huh?
