CPU I7 8700 temp while idling.
chevalier88
CPU I7 8700 temp while idling. 65C Abnormal or Normal?
PC Specs
MSI b360 gaming artic +i7 8700
Using cryorig r1 universal and cyorig QF120 fan
Casing : MEShify C
this is my Temp after idling for 10mins.
Is this normal or too high for idling..?
gld998
its normal. yours its non k variant. cannot undervolt
CrispyPeddler
PC Specs
Casing : MEShify C
idling whole time? 60+max while idling seems high. i would assume idling around 40+max and gaming around 70 max with overclock..but im using aio watercool.
also bros here recommend HWiNFO64 for more accurate monitoring
chevalier88
Idle for about 5~10mins after booting up PC.. Ok bro I try use HWiNFO64 see if got any different... yea 60+ max seem kinda high for idling.
gld998
really normal? :-O because 65C like quite high..for idling.
what is temp paste? I dont use the standard paste, replaced with MX4. Tighten properly? Change to AIO watercooling? Yeah thats pretty much u can do. :(
chevalier88
I had my PC assembled at Tradepac, so I believe the thermal pasted used was from the box given inside of cryorig r1. Not sure if he tighten it properly thou but should be professional since they help to assemble so many PCs a day?
I'm not really..very worried about the temp thou, just wanted to find out if it's normal.. and since it's normal like you said then I won't spend money on aio watercooling haha.
gld998
Suspect its either thermal paste or nvr tighten properly.
narkizy
gaming 78c still ok la for aircool :D:D
not sure if it help, u can go set your power plan to balance, set the minimum processor state to 5%?
78c normal?! Bruh what you smoking lol xD
@TS for context, my prime 15 LAPTOP CPU never runs hotter than 75c... you tell me if 78 sounds pretty damn hot to u LOL.
And its not even unlocked nor overclocked so 78 degs is bloody hot for a locked i7 chip.
gld998
laptop? its like comparing apple and orange :s22:
narkizy
My point being the the gaming-lvl cpu chips run just as hot and even more so in a crampwd laptop chassis that gives little to no room for proper cooling; compared to a very well-ventaliated chassis where the chip is mounted with a proper cryorig cooler - which should have lower temps? U tell me.
CrispyPeddler
lol. first, yours is laptop. whats the cpu?
2nd, 78c is well within the acceptable range. it wont explode your pc or anything :s22::s22:
edit: ts u can google around and see your temperature is just normal
chevalier88
hmm but cooler cryorig r1 universal costed $130++ like that and I still get such temp, isnt it weird?
CrispyPeddler
i think you started the thread just to see if your temp is normal. for me, yes. it is. it will not explode
now, if you want to get it cooler, then u can try to check if your thermal paste tighten properly (as suggested by bro gld998) / see case airflow -ve/+ve thing or even change the cpu cooler =)
