chevalier88
- Sep 21, 2012
Here's my gaming temp.
i think you started the thread just to see if your temp is normal. for me, yes. it is. it will not explode
now, if you want to get it cooler, then u can try to check if your thermal paste tighten properly (as suggested by bro gld998) / see case airflow -ve/+ve thing or even change the cpu cooler =)
Is the computer case well ventilated?
In aircon room?
To gauge cooler performance, what is the temperature when CPU under 100% load?
I do think 30-40C range when idle seems ok. As long when on load dont exceed 80C with a AIO liquid cooler.
Because this cooler I paid a hundred over bucks for it but not performing as intended? so actually wanted to know if my cooler is working as intended..or really thermal paste got issue or really not being installed properly.. hmm
and wouldn't high temp above 80C affect my gaming performance? like having shutters from time to time?
and basing on this, your cpu is running turbo boost with max clock at 4.6ghz @ 1.325v @ 74c. nothing to worry about. you are good to go
Okay bro, so do you think that there are no issues with my cryorig r1 universal ? I don't have to re-seat my cooler or apply new thermal paste to it?
But the idling temp seem weird thou for a over hundred bucks cooler hmm.
do consider delid if you want to go lower, search my nick for 8700K temp and performance. mine's delid though, and speed bumped up.
you can if you know how to re-seat and re-apply thermal paste. no harm in trying to see if it helps.
if its ME, i'll just ignore it and continue playing games![]()
delid void warranty right? and will it benefit i7-8700 non k version?
any bros here good at doing delid? considering for my k version![]()
scary bro delid if never do properly my processor will be gone..
PC Specs
MSI b360 gaming artic +i7 8700
Using cryorig r1 universal and cyorig QF120 fan
Casing : MEShify C
this is my Temp after idling for 10mins.
Is this normal or too high for idling..?
