haylui
- Jul 18, 2006
The battery is actually around 4700+mah. Should be able to last quite long.
Sent from HUAWEI MATE 10 using GAGT
4.7Ah? Got so large?mine was shown 3.75Ah
Don't think that's the case. Only in the case that the battery totally fail and will not turn on because of battery or let say the battery can only keep very very little juice and turn off after extremely short period. Otherwise if let say the battery capacity is 80% of original battery life, it's more like normal wear and tear. Don't think any manufacturer will honour that. Can try la but IMO won't succeed![]()
Yes. They stated 4000mah in their spec but if you use battery apps, you can see that the actual capacity is much higher.
Can't wait for the EMUI 9 update coming tomorrow, and can start using my mate 10 tomorrow![]()
Posted from PCWX using SONY SUMIRE
Accubattery.wutt..seriously? which battery app?
Accubattery.
You need to charge and discharge. It will show you the capacity.just downloaded. where you see its 4700mah? is it the one that you key it yourself? mine start with 1000mah![]()
My sister using Mate 20 now and EMUI 9 really seems faster than EMUI 8, been refreshing for a while for today but update not yet available.same here bro.
I cant wait to find out whether emui 9 will make the m10 snappier than it was on emui 8.
I currently owned a m20x, and noticed that the phone is able to achieve 100% after every optimisation using the phone manager.
my m20x is loaded with 90% of the apps as compared to my m10.
For me is the new camera UI that attracts me to EMUI 9, prefer it than the current EMUI 8 camera UI as the new one offers a mode to turn off Master AI too.been waiting for emui 9 also for the gestures. been using fluid NG as recommended by bros here. really good but since its not built in, there's like so many error that require me to off and on it again.
Hopefully emui 9 gestures is better!![]()
For me is the new camera UI that attracts me to EMUI 9, prefer it than the current EMUI 8 camera UI as the new one offers a mode to turn off Master AI too.![]()
any tldr on the changelog for emui 9? so far the only new i know its the gesture
btw, are we going to get android pie?
Can request EMUI 9 update in HiCare app now!
https://www.facebook.com/HuaweiMobileSG/videos/725254971188114/
