The Watch Thread - Part 15
Ed.YEO
woah even worse haha cant afford PP
nope i didnt know hahaha im a noooob in this.
i actually thought it looked a bit similar to AP :s13:
要便宜的選擇?有。。。!!!
還有金的咧!!!
只是。。。你耐得了秒針一直是在你手腕上跳呀跳的嗎?
:s13:
Ed.YEO
。。。$4-5K for ETA2824? Vs $1.6K for Seagull? There would be still people who like it enough。。。
4~5千就應該向自家機芯看了。。。普通機芯的價位叫我付超過2000。。。我總是必須抓破頭才能作決定。
Ed.YEO
Well, it draws a lot of inspiration from the PP Nautilus. But I'm sure you knew that already.
There are a ton of cheapish China random brand Nautilus homages. Bagelsport etc.
但是AP ROO咧。。。就有限了。
要買到有“質感”的。。。四位數跑不掉啦!
talonn
I am in love with the new cartier santos. The quick release mechanism is a marvel. Anyone knows which AD carries this beauty? What is the normal discount should i expect for cartier? Thanks
reikizi
I do classify movas in the same category as Azimuth, which I do hope to be able to try some day too. Premium priced? Sure, but no less logical than RM or vintage Rolex, branding aside.
ahhhh... Azimuth … I also thinking (becos Roboto jin chubi) but I can only look at second hand :(
cyrenic
Haha, a lot of nice designs!
But I like the look of Roboto..
I guess some people will say it's Roberto though :s13:
DXMachina
Bro, I just swapped out straps for Talos.
Much easier than Gorilla.
Nop's tips if it helps you later on:
1) Fit one end of spring bar into hole.
2) Move the other end as close to other hole as possible and push in.
3) Use spring bar tool to maneuver the other end into the other hole.
I suspect you won't find it a challenge. Quite the same as the Everest or Rubber B style straps.
Gorilla,.. That one is another story. Can't even see the hole.
:s13:
Thank you bro, definitely very helpful tips. I'm kinda leaving it on the kevlar strap as I think it looks the best by far, but will take note of this when I eventually switch back to rubber. :)
cyrenic
Ah, I just put it on kevlar, it really does look good! :D
