Cable Management
MaoZeDuo
Hi guys, is it a good idea if i run the cables underneath the motherboard and out from the back (2nd pic)... Quite tight though...
yusoffb01
for thicc motherboard cable can come from front if no space to close side panel
Unic0rn
your cable management is neat, but are you using a stock CPU cooler? 😮
Unic0rn
Ryzen 7 2700X (105 watt TDP) comes with Wraith Prism but the Deepcool Gammaxx 200T is an affordable budget option that can be considered too.
Secondly the Cooler Master Hyper 212 Evo is perhaps the most popular budget CPU cooler you will find, rocking it as far back as 2011! It's a solid choice for budget conscious buyers.
Lastly the Cryorig H7 offers superior cooling performance and generates less noise than the CM 212.
My intel Core i5-9600K is 95 watt TDP and using H7 that is barely able to cool it at 4.7Ghz
Koenig168
It's always neater to put the cables at the back. Newer casings have a bigger space at the back for this purpose.
MaoZeDuo
Yeap im using a ryzen 2600 stock cooler for now... Cryorig H7 is in my list
shadow84
Cant tell but did u mount the cpu 4+4 cable? Also, do check on your power front i/o cable connection and orientation. There is an arrow at back of connector, that indicates positive. Refer to manual for orientation.
For rear fan, not recommended to run its cable thru mobo cutout. Coz u will be restricting urself for any future upgrades. Very mafan to remove mobo just to take out rear fan.
One more thing to take note, your cpu cooler is on intake position, not exhaust. If ur rear is exhaust, u will be starving the cpu fan of fresh air. And cpu eill be quite hot on idle and load. Kena this issue with my fren case.
MaoZeDuo
Thanks. Currently rear and sides are exhaust and bottom is intake. So ideally is to flip the cpu fan - i need to google how to do so lol
Manage to boot (pwr switch put wrong)... now stuck at uefi bios, but cannot find the option to install windows...
I installed the polaris fans before i connect the wires... it was tough... 2 sets of 3 fans daisy chained and connected to 2 rgb headers... fans are running but the lights not up...
shadow84
Iirc, u cant switch position of cpu fan coz its designed as such.
If u have win os on a bootable thumbdrive, select that usb key in bios and boot up from there. Bios wun have win os setup files de. Also, dun connect ur hdd, only connect ssd which is meant for ur os.
As for rgb fans, it will light up once u enter windows after setup. Also since u gt 6 rgb fans, consider getting the CM 1-3 rgb splitter. Helps a lot. If not a rgb hub although i dunnoe if there is one that supports 6 rgb.
MaoZeDuo
Thx shadow! I actually have one win os on a thumbdrive downloaded in 2016 and i found it and followed ur steps... installing now!
My lights are up - the connection to rgb header was loose (and still is, is this normal?)... any advise if i still need CM 1-3, given the specs below? currently 3 daisy chain to each rgb header.
1st DIY! very excited!
shadow84
Iirc, each rgb header can take up to 3A current but best to double check on ur manual.
Connection shld be quite secured. Did u push all the way in?? If daisy chained together into 1 rgb header then shld be fine. No need for splitter.
