SSD Price dropping......
Lex1989
Never buy from Newegg.
But interested in getting Crucial MX500.
Any local retailers carry this brand and model?
Why buy local when online is so much cheaper?
My Crucial M4 128gb still running well since how many donkey years!!
buying from Newegg or amazon is so much cheaper.
I will study first. Uncle noob online shopping..
even lazada, shopee etc also never try buying my ownself.
If Crucial SSD got problem, then warranty how ah?
Also, any offer for MX500 @ 500 GB?
Thanks.
lifeishard
Thanks.
if that is the case then you better go buy from shop or online but choose local stocks.
for overseas crucial ssd we will liaise with them online and follow instructions given (most probably sending to taiwan on our own).
For local stock, you go to Convergent System at Ubi crescent for exchange.
wayne085
haiz regret not buying 2 2tb 860 evo during black friday so i can use 1 for my pc storage and another to upgrade the ps4 storage
now price all shoot back to 600 for 1 860 evo 2tb
watzup_ken
Then I will camp for ur thread.
Pruss huan for chiu :s12:
BTW, anyone ever used the WD Green Series SSD?
Heard it's SLC, not sure is the entire drive or just the flash cache.
You should find out more about it by Googling. It's a DRAM-less SSD, and works with SLC cache. No chance at the low end will you get actual SLC NAND. Even the cheapest MLC SSD is quite pricey.
watzup_ken
any specific reasons why? been seeing pple say this. is it just the usual trend of tech improving hence less costly to produce or due to the drop in demand for mining or??
Many reasons. One is the short supply of Intel causing slowdown for new PC, also a decline in demand for high end mobile phones, coupled with an improve in supply in NAND is putting pressure on price.
matrix05
do ssd local warranty help? typically how long does it last?
MX500 480GB, Sandisk Plus 480GB and others can get below 2 digits S$99 (either Lazada,Q10,Shoppee,neweg when there is a promo) from local sellers. Amazon US is USD58.
swathe
SSD price steadily dropping. RAM seems to have stabilized and DRAM prices forecasted to go back up end of 2019.
007Mi6
Anyone try Silicon Power P34A80 2TB? Endurance quite high at 3000TB and only about USD250++ from Amazon
Pocoyoz
worth to buy mx500 1TB $163 :s11:
or buy nvme better?:s11:
using H97 chipset:(
SkyShroud
using H97 chipset:(
u muz check if ur mb support nvme first
if not, u cannot use normal ssd unless u get a pcie nvme adapter
note that adapter cannot be used as boot drive
as for the price...mehz...a cheap nvme will have similar performance
unfortunately, all local ssd is expensive
Pocoyoz
1 x M.2 Key M Socket both PCIE Gen2 x2 & SATA mode
support mah
