OFFICIAL ONEPLUS 6T!
rootz
Well, most ppl will sure put case de. So question is, why buy Maclaren when a normal 6T would suffice? And function the same (as in, would the extra ram help, when comparing 8 and 10Gb?)
Synnexo
Very amazed by this phone's reception, better than my iPhone, always get full bar
This observation has to be clarified. OP reception is not better than iPhone. If u use custom ROM, u can see the reception is the same as any other phones.
Gixxerfied
Receive SD TG..
Left Original, Right is SD. Can see SD black edges is slightly thicker than original on top(Near camera) and bottom. Barely noticeable after applying since it doesnt block any visible icons/labels.
Gixxerfied
Yup..cover just Abit top and bottom..not too bad, after all it's about $10 for 2 pieces..
KeYoKe
Ya man, is urs the uk 3 pin plug? I saw youtube reviews those uk sets came with the proper 3 pin plugs. Mine is the 2 round pins. Disappointing man.
nope, mine is the china 2 flat head plug. your one the 2 round head can take out? maybe they just install a adapter to convert from china plug to 2 round head? :s13:
princewenle
Tia gong they are going to release McLaren with the thunder purple... Is it true?
Sent from HUAWEI MHA-L29 using GAGT
