Samsung Galaxy Watch
samsungXP
Did anyone noticed your estimated battery life remaining is shorter than before after this current update?
When the first update came just after it’s launch, I am able to get up to 3 days of usage or minimum 2 days 20+hr on full charge. On 42mm, HRM set to 10mins, Wifi off.
After this second update, a full charge only gives me 1 day and 23 hours of estimated usage. No change in usage patterns.
Cheers.
this sound bad
Sent from Honor 10 Phantom Blue using GAGT
Montoya
how come i can't update ah ?
I keep tap tap tap on that part also nothing happens
Both my phone and watch is on same wifi network
have you tried clearing cache on galaxy wearable app on phone?
Montoya
SW update available.
- Fix BT connection issues
- Fix NFC battery draining issue
- Improve GPS performance and accuracy
grab this update if you're using strava tizen app. prior to this update gps does not work at all.
ev960d
When I try register my watch on Samsung website, I ran into BP Number Invalid error. Can someone help to explain what is this BP number?
wwh5210
Email to Samsung SG is the fastest way to solve ur problem. Their warranty registration system is a bit cui lol.
PeasantBeing
I am using free watch faces with 3 complications.
Sent from Rocket Uno cruising in Midnight Black Galaxy No. 9 using GAGT
earthtk
Does anyone knows how to change the rest timing for exercise after each set? The default is set to 1 minute
Gloom me
Sian I bought the 42mm then regret.
Anyone wants to trade 46mm for 42mm? :(
