Nokia
robolee
I am still on Oreo, your 7 plus no battery problems and other system issues after upgrade to Pie?
negative, infact it's much smoother now. 1 day charge 1 time if i had to go out if not dun even need to charge at all :s13:
HL
Thanks. I read a lot of bad feedback after the PIE update, I think you must be lucky!
tiger2013
HMD Global has launched the Nokia 8.1 in India. The phone is priced at INR 26,999 ($372) and will be available in only one variant, starting December 21, with pre-orders starting December 10. The phone can be purchased across all major offline retailers as well as online through Amazon and Nokia.com.
The Nokia 8.1 is a mid-range smartphone. It has a 6.18-inch, FullHD+ IPS display. It runs on the Qualcomm Snapdragon 710 chipset and comes with 4GB of RAM and 64GB of expandable storage.
indian price not cheap :(
Pricing somewhat similar to Mi A2/Mi A2 Lite when it was just released on similar specs...
Mid-range devices prices are increasing faster than salaries can increase, lol. Next time can only buy low end devices liao.
tiger2013
Do you guys think Nokia will be back in the smart mobile industry game?
No
Unless Nokia comes out with something better than iOS and Android.
Microsoft, with all its resources, failed. Google is nowhere near the success of Apple.
However, Nokia does have some advantages which IMO it has not taken advantage - hardware and telecommunication engineering knowledge. They should marry both to create a product that's stable. The closest competitor in terms of profile similarities is Huawei.
Posted from PCWX using PCWX
stillgottheblues
So far their products has got no unique selling point except stock android. They need to produce something consumers wanted.
tiger2013
Nokia 8 Android Pie has arrived.
tiger2013
Android Pie update is giving me some headache, namely installing/updating apps and unable to sync/search my Bluetooth devices.
Based on Google searches, one cause of the problem is the Google app. Need to disable Google app to get things working. Not sure if disabling Google app will cause major issues. I have not tested further.
If you use Google a lot, then temporary solution is to disable and re-enable Google app as and when you need to sync/search for Bluetooth devices and update your apps.
Not sure if anyone of you encountered this issue.
tiger2013
I think the storage of the Google app might have some corruption during the upgrade.
I re-enabled Google app, cleared the storage data and tried to install some apps. It's working again.
8-lane
Nokia has at last come out with a slim bezels, notch-less model... the 3.1 Plus (BUT it is relegated to the low end) !!!
靜雞雞地,諾記於本地市場推出入門機款3.1+!
Mustafa $238.
Ps ah.. my Chinese not gd.. is it a local set?
TheHome
Just purchased a new Nokia 3.1 today as my spare phone. Couldn’t source for a good case and glass. Anyone has a good recommendation to buy online or physical shop? Appreciate much!
tiger2013
Fingerprint sensor now behind? I like it the way it is on Nokia 8...
8-lane
Ah... so high end one is in front and more expensive to make?
Did i say that? :s8: If u wanna make a fair comparison.. compare with other phones of similar price segment/class segment (ie. low end/high end etc)..
