If u re thinking to get at IT Show, Then wait for P30.
Thank you
Thank you
The freebies when you buy the phone, yes. Don't think it includes reader if you buy separately.does the nano memory card comes with reader?
Might as well as ask him to wait few more months for mate 30?
Wait. After few more months p40 should be out
Wait. After few more months mate 40 also out
Buy graveyard better
I've found that only Huawei stock launcher is. Most stable...
Other launchers keep getting random crap.like can't connect to camera and other UI quirks..
Posted from PCWX using LYA-L29
I'm using nova launcher, so far so good.
New to android
What is the nova launcher for? Seems alot of mention here. Tia
Does anyone have an issue with a burn in screen. My Mate 20 pro has a thick horizontal line across the screen and it's quite obvious when the screen is off. Looks like what seems to be a notification bar marking.
You can just go 313 and ask for 1 to 1 exchange. May i know your screen LG or BOE ?
Will they allow me to do so? I mean they can say a lot of things like it's normal etc. Mine is an LG screen.
need to bring whole box an charger etc?I just changed mine yesterday. Just said green screen and they record it and dont even bother to check and ask ke come back later for a new set. Just bring your phone there will do , you will given a brand new sealed set
Can take Pic to see the coverage?just went to rwm to get their tempered glass. Very satisfied with it, and tried few cases and fit perfectly without glass lifting at the sides. 30 bucks well spend.
Sent from HUAWEI LYA-L29 using GAGT
