Hi,
Anyone got any shops on online mall to recommend for Mi Pad 4, Wifi version will do.
Thanks.
Hey bro,
I ordered from finer from qoo10 portal
not local set i think
https://m.qoo10.sg/shop/finer?__ar=Y
Hey bro,
https://m.qoo10.sg/shop/finer?__ar=Y[/QUOTE
There is no local set
Hey bro,
yeah hence I said not local set
but kinda regret ordering the 10.1" as it comes with 4G but don't really need it as mainly for home use but way cheaper than normal big sized tablets so
never will mi pad 4 get official global. dont even think about it. most prob is unofficial rom.
H9w much u bought
Havoc OS for Mi Pad 4 is the best, much better than EU rom IMO.
https://forum.xda-developers.com/mi-pad-4/development/rom-havoc-os-v2-0-t3881690
just curious, was there any issues with MIUI on the Mi Pad 4 that triggered you to use Havoc OS ?A new version just got released, installed and running good.
This version seems to fix Netflix install via Playstore too.
Install Google Cam and takes even better picture than MIUI camera. Currently using this version myself, might have a newer n better version but yet to try.
I suggest you folks give this ROM a try.
I feel like trying Havoc OS but MIUI seems to be good enough for my usage
but miui is the only rom with full dual apps and second spacePersonal preference over MIUI i supposed. Have been using custom ROMs for years and become more comfortable to stock or near stock Android ROMs.
Footprint for MIUI is always bigger than custom ROMs no matter how we debloat them.
Moreover Havoc OS is on Pie, whereas i believe MIUI for clover is still at Oreo.
it's very good for abusing apps with referral bonusFortunately for me, i'm not using both features
main app refer to second app then clear data and start over
