SP gg liao... *********
Sent from Huwei Mate 20 Pro using GAGT
Where is your SP from?
Can try getting from Shopee, carousell, Qoo10, lazada or whichever one is cheaper.Just recontracted and got M20 from M1.
Previous was M10 owner and switched to M20 now.
Any recommendations for the nm card and card reader?
Get from shops like RedWhite, J2, moby, mobile square, kasia, hitecmobile. Camp for coupons from qoo10 cuz it will usually be cheaper.Planning to replace my Xiaomi Redmi Note 3 cos the camera is very cui.. I'm not recontracting, just gonna get the phone itself..
Last time I read a post regarding a bro here computer cannot read the memory card using nano card reader. Today I opened mine and realized I got the same issue. Do I need to install any driver for this?
So is it normal or what? Because mine is the replaced model after the LG incident of green screen.
The main reason that I chose Mate 20 is because I prefer IPS than oled screen beside price different.Why not mate 20 pro?
Normal bah. Refraction
Had the same issue before.
You need to push in the card completely, with a needle or paperclip. Then then it works
It’s worse than normal actually.
I have bad experience on both my previous Asus zoom S and Samsung S7, all got burn mark on top of the screen after my long reading behaviour.
Hey guys...
Anyone using google photos?
For my other phones, Google photos usually auto backs up to cloud.
However for mate 20 pro, I need to manually open the app to kick start the syncing.
Anyone face this issue?
Thx
Posted from PCWX using LYA-L29
mine is working. did you allow it to run in background
Hi guys,
Have any of you tried putting ring holder on the back of the phone and still able to use wireless charging? If yes, what kind of ring holder did you use and where did you place it?
which telco in sg has midnight blue for mate 20 pro?![]()
