Cause it is inside a cabinet that comes with the desk. I am not gonna change my desk.
Then you should really put some serious thought into buying a tower server from Dell, HP or Lenovo since it's a major point of contention. Forget about your existing hardware.
Only tower server chassis will have front-loading HDD bays that are directly wired to the motherboard for hot swapping.
On the plus side, it comes with Xeon processors and ECC memory that are superior to consumer trash.
Most people usually have 1 or 2 hdd. Not like every week need to swap out the hdd. Set once and forget.
Don't recall corsair having a mid sized version of the 800D that has hot swappable bays. You'll have better luck looking for those optical drive to 3.5 hdd bay slots. For the record, I'm still using an old full tower Antec df-85 from 2010, back then they also offer a mid tower version(iirc) that had hot swappable front bays.
Aesthetics wise, it has an industrial look that might be considered unpleasant looking for some, but it has all the bells and whistles that i need that made me reluctant to replace the casing.
Phanteks P300 got 2x front load HDD...
Then that's entirely your problem. I'm not sure how you managed to turn your problem into blaming other consumers.
Silverstone CS380?Thanks. Will look more into it but the usb is accessible at the top which if under my desk, it will not be accessible.
In a way, this is a situation in which you had chosen to inflict upon yourself and its not a direct design flaw from makers. So, it would be unfair to blame makers for the decision you had made.
My 2 cents.
Silverstone CS380?
Anyone knows where to get Silverstone CS380 locally?
Silverstone CS380?
Call the distro (Avertek) to enquire.
Received the case more then a month ago.
Dismantled it & today just sent for powder coating. Was told that he hasn't done casing for a few years already.
Wow
So practically no one does this anymore?
