Cannot also. Need to manually enable the other sim to get data from other sim. Btw, when u enable dual sim 4G, does both ur sim displayed 4G at status bar? Mine only TPG 4G even though both also set to auto, G/WCDMA/LTE.
Same
Sameso I didn't feel there is any diff whether it's set to dual 4g or not.
Same as in only one 4g display?
I still can take screenshot in the posb digibank appAfter my upgrade, DBS banking apps is now unable to be screenshot. Anybody had this issue too? Any workaround as screenshot is useful to capture evidence/details when transferring fund.
My current workaround is to login from website to get the details :-(
Use the screen capture from the drop down menu?After my upgrade, DBS banking apps is now unable to be screenshot. Anybody had this issue too? Any workaround as screenshot is useful to capture evidence/details when transferring fund.
Sent from HUAWEI MATE 10 using GAGT
Uob has this restriction but they have a save to gallery icon. Dbs should have similar too.Thanks guys... guess its only restricted on the DBS iWealth apps then :-(
My OCBC apps can also be screen captured.
Thanks for trying on your phones.
I was about to ask about this too. Just updated to v159 on non pro. Noticed my battery draining very fast. Wanted to find the location to see if it was set wrongly. Can't find the locating method icon too!
this android pie update finally solve my wifi woes of 1 year 2 months
Are you using a sinktel router? Haha.
All is good for this phone (mate 10) except it is unable connect to hidden WIFI which open a browser to require username and password. Can't even connect to overseas Hotel WIFI... haizzz
