CPF Accounts Value thread
tangent314
Moderator
Moderator
Bro, i use this scenario; SA stays at 88k for easy comparison on 55yo onward.
On 55yo, should i do FRS or ERS ? Below be FRS.
This has been asked many times before and always ends up triggering a heated debate...
I'm in the ERS (+escalating) camp FWIW
SKenny
zuppeur
Yes to your first question.
Not sure about your second question. The reason why you want to pledge your property is to withdraw upto 50% of FRS. If you intend to park the fund in RA from the start, then why pledge your property?
Please note that you can choose to pledge your property at a later date beyond 55 until when your CPFLife starts.
Sorry for the newbie question.it sure does it make sense.
1.@55 I choose FRS.
2.Top up using cash to ERS
Since I choose FRS. How much will be transfer to cpf life and When will happen to the top up fund? Remain in RA acct
SKenny
1.@55 I choose FRS.
When you top up your RA to ERS, the top-up amount is "stuck" there. It will then form part of your CPFLife payout.
You cannot withdraw the top-up amount in your RA (unless under some extreme conditions).
You can withdraw part of your FRS (ie the amount that you placed in RA as per your above example), as part of the pledging of property. The 20% withdrawal option is available too.
SKenny
And initial RA can be ers ?
Technically when you turn 55, the RA is formed with FRS as the limit.
You can then increased the RA to prevailing ERS via top up (cash or CPF).
Please note that top up monies is treated differently from the initial FRS amount as there are more restrictions on the top-tup. For example, top up amount cannot be used as part of the calculation of the amount that can be withdrawn in a property pledge.
BBCWatcher
However the ERS limit is "cast in stone" at the point when you turn 65.
I'm not aware of any BRS/FRS/ERS cap starting from age 65. Are you thinking of the Basic Healthcare Sum for MediSave, which is fixed on your 65th birthday?
alt2015
Thks. I will be able to withdraw only up to 20% of Frs (inclusive of interest?
But not 20% ers .
SKenny
But not 20% ers .
For the 20% withdrawal, interest earned is included but top up (and other grants if any) are excluded.
For calculation of BRS, interest earned (and top-ups, grants etc) are excluded.
SKenny
You are correct, I got it mixed up with BHS! You can top up RA beyond 65 years old.
Any top-up after you start your CPF Life (say at 65 years) old, get paid out as Additional Monthly Payments which are prorated till you are 90 years old.
You can also apply for additional CPFLife with these top-ups (until 80 years old).
JuniorLion
It would be best to use cash to top up your newly-formed RA from FRS to ERS at 55 immediately, even if you have sufficient SA to transfer to RA.
iMac
I do not quite understand this....
Most ppl hardly can't wait till 55 to take out their $ from CPF, why you put in $ into CPF instead ?
JuniorLion
Guaranteed 4%. Life annuity. SA functions as 4% savings account after 55. What's there not to like?
BBCWatcher
good tip. more grub for the 4% machine... :D
Yes, agreed. A 4% interest earning "on demand" AAA-rated government guaranteed account (your Special Account at age 55+) is a rather expensive source of funds for top-ups.
Nofear40
They will not take from SA followed by OA once you opt for ERS?
Can I choose to transfer from OA to ERS and leave my SA balance intact ?
kehyi4
maybe because the people who frequent this forum are not your average typical Singaporean
JuniorLion
FRS is formed from SA first. If you have insufficient SA, they will use OA to form RA. If you want to leave your SA balance intact, you gotta do the SA shielding trick.
