knave
- Jan 1, 2000
Why unable? I can connect to such WiFi with no issues at all. If your browser for some reason can't be auto launched, then you manually launch it yourself. Browse to some website like hwz or something and the WiFi which you are trying to connect will redirect you to their login page.
Have you updated to Pie?
If yes, check if you have enabled private DNS feature. If yes, disable it to connect to those free wifi
Posted from PCWX using HMA-L29
